Rockhopper web-server
- LearningLinuxCNC
- Thank you received: 48
03 Sep 2015 20:57 - 03 Sep 2015 20:58 #62090
by LearningLinuxCNC
Rockhopper web-server was created by LearningLinuxCNC
Yesterday Andy Pugh directed me to the Rockhopper web server application for getting a graphical representation of a HAL configuration.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Rockhopper_Web_Server
I tried to install it yesterday and I am getting the following error when I try to run the application.
I followed the directions on the Rockhopper readme and on the Tornado install but I am getting this error. Something must have gone wrong somewhere.
jim@RB1-CNC:~$ cd Rockhopper
jim@RB1-CNC:~/Rockhopper$ python LinuxCNCWebSktSvr.py /home/jim/linuxcnc/configs/RB1-CNC_Gmoccapy_DEV_1_00/RB1-CNC_Gmoccapy_CustomBox4.ini
File "LinuxCNCWebSktSvr.py", line 27, in <module>
import tornado.web
File "/usr/local/lib/python2.7/dist-packages/tornado/web.py", line 88, in <module>
from tornado import iostream
File "/usr/local/lib/python2.7/dist-packages/tornado/iostream.py", line 40, in <module>
from tornado.netutil import ssl_wrap_socket, ssl_match_hostname, SSLCertificateError, _client_ssl_defaults, _server_ssl_defaults
File "/usr/local/lib/python2.7/dist-packages/tornado/netutil.py", line 39, in <module>
import certifi
ImportError: No module named certifi
jim@RB1-CNC:~/Rockhopper$ ^C
Last edit: 03 Sep 2015 20:58 by LearningLinuxCNC.
- racedirector
- Thank you received: 42
03 Sep 2015 21:04 #62091
by racedirector
Replied by racedirector on topic Rockhopper web-server
Found this via Google for certifi
pypi.python.org/pypi/certifi
Not sure what to do to install it though
The following user(s) said Thank You: LearningLinuxCNC
- LearningLinuxCNC
03 Sep 2015 21:21 #62092
by LearningLinuxCNC
Replied by LearningLinuxCNC on topic Rockhopper web-server
Ah yes, why did I not think about google. That got it a little further. Now for some more googling to find out what to do next.
Looks like I need to update my python libraries. Will this break anything with LinuxCNC if I do so?
- LearningLinuxCNC
04 Sep 2015 07:52 #62105
by LearningLinuxCNC
Now I am having trouble with the following error.
I found where I can download backports.ssl_match_hostname but I don't see how to install it. Does anyone know anything about this. There is a setup.py file in the tarball but when I try to run it I get the following.
I know this is not really LinuxCNC stuff, but I am trying to get something running for LinuxCNC and this is the bumpy path to get there.
import tornado.web
File "/usr/local/lib/python2.7/dist-packages/tornado/netutil.py", line 58, in <module>
import backports.ssl_match_hostname
ImportError: No module named backports.ssl_match_hostname
jim@RB1-CNC:~/python/backports/backports.ssl_match_hostname-3.4.0.2$ sudo python setup.py
[sudo] password for jim:
usage: setup.py [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
or: setup.py --help [cmd1 cmd2 ...]
or: setup.py --help-commands
or: setup.py cmd --help
error: no commands supplied
- racedirector
04 Sep 2015 07:55 #62107
by racedirector
I've been playing with this since I saw your post and finally got Rockhopper to fire up. With the backports thing do this
and it should install automatically
sudo pip install backports.ssl_match_hostname
- LearningLinuxCNC
04 Sep 2015 08:20 #62108
by LearningLinuxCNC
Yeah Buddy! That did the trick. Rockhopper is up and running. Pretty neat features. The graphical HAL is pretty cool but in my config there are many signals all running together so you can't really tell which one is going to where.
Thanks for the help.
The following user(s) said Thank You: racedirector
Time to create page: 0.349 seconds
