After Home - Y axis takes off in negative =SOLVED
- jwaldo
07 Sep 2015 19:07 - 07 Sep 2015 23:29 #62194
by jwaldo
After Home - Y axis takes off in negative =SOLVED was created by jwaldo
Thank goodness for this forum.
Homeing In Axis,
Z axis first, up, finds home switch, down till switch off.
X axis, negative direction, finds home switch, backs off.
Y axis, negative direction, finds home switch backs off.
I would assmue the machine is homed at this point.
Immediately, the Y axis takes off in the negative direction (I'm glad I put those limit switches in)
Loaded G code program contains nothing (I wrote a blank program)
(Test)
(does nothing)
Interesting, the cone in the Axis display moves correctly for the Z axis. For the Y and Z it moves the wrong way (moves positive when gantry router is moving negative). If I switch direction in StepConf - then it moves the wrong way to find the home switches.
I'm stuck.
Thanks,
Jim.
Homeing In Axis,
(Test)
(does nothing)
I'm stuck.
Thanks,
Jim.
Last edit: 07 Sep 2015 23:29 by jwaldo.
- BigJohnT
- Thank you received: 994
07 Sep 2015 20:09 #62196
by BigJohnT
Replied by BigJohnT on topic After Home - Y axis takes off in negative directio
Change the sign of the homing velocity to reverse direction.
BTW, understand what happens or rather what does not happen when you use the % to wrap your code. Much safer to use a Program End and a proper Preamble.
linuxcnc.org/docs/html/gcode/m-code.html#_m2_m30_program_end
gnipsel.com/linuxcnc/g-code/gen01.html
JT
JT
- cncbasher
- Thank you received: 202
07 Sep 2015 22:03 #62197
by cncbasher
Replied by cncbasher on topic After Home - Y axis takes off in negative directio
just for info,
try and change the mechanics of your build rather than rely on using invert or - parameters
makes it so much easier later on , when you start add more complexitys
i.e reverse the sense of the stepper motor direction by swapping a+ coil etc
so the direction sense becomes correct .
ok it's a bit more work but pays dividends later
then the last resort is to use negative values in your ini
- jwaldo
07 Sep 2015 22:15 #62200
by jwaldo
Replied by jwaldo on topic After Home - Y axis takes off in negative directio
BigJohnT,
Thanks, I'll spruce up the code.
cncbasher,
Thanks, I will swap a coil.
Jim.
cncbasher,
Jim.
- jwaldo
07 Sep 2015 23:28 #62207
by jwaldo
Swapped the coils, gate it a negative home velocity, and a real CNC program and
it works!
Thank you very much for the assistance.
Jim.
it works!
Jim.
- Doug @ Design8Studio.com
- Thank you received: 46
10 Jan 2023 15:53 - 10 Jan 2023 16:05 #261458
by Doug @ Design8Studio.com
Replied by Doug @ Design8Studio.com on topic After Home - Y axis takes off in negative =SOLVED
Hey, I'm experiencing an issue in dual Y axis homing that is basically what was described here. The answer is a bit confusing to me. Should I discuss here? or post a new topic?
EDIT: Since this topic is already marked as solved, I started a new topic here:
www.forum.linuxcnc.org/49-basic-configur...n-negative-direction
Last edit: 10 Jan 2023 16:05 by Doug @ Design8Studio.com.
- Thank you received: 7491
10 Jan 2023 16:03 #261460
Replied by tommylight on topic After Home - Y axis takes off in negative =SOLVED
Video ?
10 Jan 2023 16:05 #261463
ok, will shoot video.
10 Jan 2023 16:27 #261467
I uploaded HAL and INI files and linked video, all over here:
www.forum.linuxcnc.org/49-basic-configur...ive-direction#261466
Time to create page: 0.098 seconds
