LinuxCNC job data storage
- hweiyiping
08 Sep 2015 16:15 #62233
by hweiyiping
LinuxCNC job data storage was created by hweiyiping
I'm trying to write an algorithm based on real data from milling jobs. I was wondering if LinuxCNC stores all that data somewhere. I have all the gcode. But I'm thinking that each time that the machine mills something, LinuxCNC should generate a log that records when the job started/ended, the spindle speed, if any error occurred, etc. I've found that the settings are stored in linuxcnc-configs, but where is all the job data? The machine was set up using LinuxCNC Stepconf Wizard. Any help will be greatly appreciated!
Thank you!!!
Thank you!!!
- ArcEye
- Thank you received: 758
08 Sep 2015 16:28 #62234
by ArcEye
It does not. Nor will you have read anything that says it does.
There are various posts on the forum regards job timings etc that can be applied additionally.
Replied by ArcEye on topic LinuxCNC job data storage
The following user(s) said Thank You: hweiyiping
- Thank you received: 1467
09 Sep 2015 03:05 #62283
Replied by Todd Zuercher on topic LinuxCNC job data storage
Is this something like what your asking for?
www.linuxcnc.org/index.php/english/forum...26-time-studdies-ugh
I never completely finished getting it to work like I'd like it, then priorities changed. But maybe it might give you some ideas.
- hweiyiping
09 Sep 2015 08:59 #62296
by hweiyiping
Replied by hweiyiping on topic LinuxCNC job data storage
Ahh thank you... Been looking everywhere and not finding anything. Thanks for confirming. So I'll need additional sensors and processor to get any real time job data? I was thinking at least LinuxCNC would generate an error message when an accident happen, e.g. the tool bit ran into the workstation?
- hweiyiping
09 Sep 2015 10:17 #62299
by hweiyiping
Yes recording start/end time sounds like a good start. Will look into it. Thank you!
- hweiyiping
09 Sep 2015 14:48 #62308
by hweiyiping
So I followed the instruction and added the python file to where my ini file was. Then added loadusr -W ./timelog.py to the hal file. When I started LinuxCNC I got this error msg:
execv(./timelog.py): Permission denied
./timelog.py exited without becoming ready
Any idea why it happened? Did you get anything like this? Thank you so much!!
- cncbasher
- Thank you received: 288
09 Sep 2015 16:03 #62309
by cncbasher
Replied by cncbasher on topic LinuxCNC job data storage
go to the file and make it executable, this is not done by default in linux
- BigJohnT
- Thank you received: 1176
09 Sep 2015 17:55 #62314
by BigJohnT
LinuxCNC would have no idea that a tool hit anything unless it overloaded the spindle drive or axis drive then that could be reported.
JT
Replied by BigJohnT on topic LinuxCNC job data storage
JT
- hweiyiping
10 Sep 2015 08:56 #62368
by hweiyiping
That fixed it. Thank you!
I use an AXIS GUI. I found some useful info from Machine --> Show LinuxCNC Status. I know that it's a python program called linuxcnctop that pulls all the info. But I can't execute linuxcnctop.py in terminal or find the program that calls linuxcnctop. What I want to do is to automatically log the info pulled by linuxcnctop.py and generate a .txt. Any thoughts? I'm really new to this so any comment will be helpful
- BigJohnT
10 Sep 2015 18:34 #62379
by BigJohnT
You can use the Python Interface to read just about anything that the status window shows.
linuxcnc.org/docs/html/config/python-interface.html
JT
JT
Time to create page: 0.132 seconds
