Error after close LinuxCNC
  • jstoquica
  • jstoquica's Avatar Topic Author
  • Premium Member
  • Premium Member
10 Sep 2015 21:28 #62400 by jstoquica
Error after close LinuxCNC was created by jstoquica
When I close the LinuxCNC window, in the terminal appears this error message:
X Error of failed request:  GLXBadContextTag
  Major opcode of failed request:  154 (GLX)
  Minor opcode of failed request:  103 (X_GLXDeleteLists)
  Serial number of failed request:  17629
  Current serial number in output stream:  17630
Actually I don't have problem with the execution of any configuration, but I don't know the meaning of the error.
Regards.
10 Sep 2015 22:15 #62402 by ArcEye
Replied by ArcEye on topic Error after close LinuxCNC
If you google the error, you will see it can occur for a number of reasons.
One of the main ones is that your video card's rendition of GLX not sitting happily with openGL.
nvidia or ATi cards using proprietary drivers often throw this.
The other common one is when accessing remotely through ssh or similar.
Either way it is an X problem, not one with linuxcnc
The following user(s) said Thank You: jstoquica
  • jstoquica
  • Premium Member
  • Premium Member
30 Nov 2015 18:40 #66127 by jstoquica
Replied by jstoquica on topic Error after close LinuxCNC
Thanks,
I understand of the proprietary dirvers. I did a test with root user and the error or warning message didn't show again. Can I do anything for improve that issue?
I am working with a linuxcnc compiled package (in root mode) so I run my own conf. in RIP mode and after that I rebuild linuxcnc to work without RIP mode and use all the benefits of linuxcnc.
Thanks.
