thats fine , ask all the questions you want?
we really need to know more about the machine you have , do you have the stepper motors etc
the chinese tb6560's can be a nightmare , but they are becoming better , the biggest problem by far was identifying the pins for the parallel port
as sometimes their are 3 or 4 different versions of pinouts , if you search the forum you'll find the thread , and no doubt some configurations to match
the main parts we need to know to interface with is , what power supply do you have for the motors ( i believe the tb6560's have a max of 36v , by memory , so that means no more than say 30v )
and what stepper motors you have ,
also if you have or intend to fit home and limit switches , and a must have Estop ! ,
if anything post a picture of your machine , and if you have a copy of the instructions for the tb6560 as a pdf that will help
to start with you need to know what your using on the stepper motor to move the axis , i.e belt or ballscrew & the pitch of this ( tpi / mm ) needs to be known , along with if the motor is directly to the ballscrew or via a pully reduction ..
so much to take in haha , so we can do this in stages ...
and of course welcome to Linuxcnc
