Mesa 7I90 and linuxcnc
- nilrods
29 Oct 2015 03:52 #64413
by nilrods
Mesa 7I90 and linuxcnc was created by nilrods
I search around the net some and there seems to be a linuxcnc driver for the Mesa 7I90.
Just wondering if anyone is using one and if it works well.
I am only looking for steppers and a spindle encoder right now so really don't want to go for the spendier Mesa Boards just for that.
Any thoughts would be appreciated.
Thanks,
Chris
Thanks,
Chris
- Online
- Thank you received: 5330
30 Oct 2015 00:24 #64477
Replied by PCW on topic Mesa 7I90 and linuxcnc
The 7I90 is supported though I dont think there are any example hal files
if you started with a 7I43 ini/hal file set and changed the 7I43 text to 7i90
and deleted the firmware=xxxxx token in the config line you would
be pretty close to a working 7I90 config
The following user(s) said Thank You: nilrods
Time to create page: 0.095 seconds
