Old Install having new issues!
- tjamscad
29 Oct 2015 23:42 #64472
by tjamscad
Old Install having new issues! was created by tjamscad
We are using Axis, LinuxCNC 2.4 pre. The issue is that it started moving on its own. Only when commanded the Y-axis will start moving and stays moving. We normally use the keyboard arrow keys to move the axis. When you press the arrow key + or - the Y axis starts moving and stays moving even after letting go of the arrow key. While it is moving if you press the opposite arrow key it will change directions but stays moving. If you press the arrow key multiple times it will speed up. Once it is giving a command the axis stays moving until you e-stop.
- BigJohnT
- Thank you received: 994
30 Oct 2015 04:32 - 30 Oct 2015 04:58 #64488
by BigJohnT
Replied by BigJohnT on topic Old Install having new issues!
I'd start by watching axis.1.kb-jog-active if it is in 2.4. If it stays on after you release the key the problem could be the keyboard.
Edit: If you didn't upgrade the software then nothing has changed there, so look at hardware keyboard, harddrive etc.
JT
JT
Last edit: 30 Oct 2015 04:58 by BigJohnT.
- tjamscad
30 Oct 2015 19:37 #64511
by tjamscad
Replied by tjamscad on topic Old Install having new issues!
It will also do it with the keyboard unplugged using the +/- on the display with the mouse provides the same results.
- BigJohnT
30 Oct 2015 19:45 #64512
by BigJohnT
Well that does eliminate the keyboard... what do you see when you put the hal pins for the Y axis in a watch window?
JT
JT
- tjamscad
30 Oct 2015 20:03 #64514
by tjamscad
axis.1.kb-jog-active toggles true/false as it should.
- BigJohnT
31 Oct 2015 04:38 #64530
by BigJohnT
That does sound like the drive is not stopping when the jog command is removed. I'd put the Y axis drive pins in a watch window and see what they are doing, if they stop when you remove the finger from the key then something down stream is stuck. What kind of drive it is stepper or servo?
JT
JT
- tjamscad
31 Oct 2015 05:43 #64532
by tjamscad
Turned out to be the motor encoder missing feedback.
- BigJohnT
31 Oct 2015 18:44 #64546
by BigJohnT
That would do it for sure.
JT
JT
Time to create page: 0.197 seconds
