Why can't I reply in my own topic?
- Razor_keen
- Thank you received: 4
14 Nov 2015 05:23 #65219
by Razor_keen
Why can't I reply in my own topic? was created by Razor_keen
I cant seem to reply to my topic in Installing linuxcnc. It's titled Ubuntu 14.04.1 linuxcnc help. Why cant i reply in this topic
- ArcEye
- Thank you received: 240
14 Nov 2015 08:50 #65234
by ArcEye
Replied by ArcEye on topic Why can't I reply in my own topic?
I don't think anyone can reply, certainly comes up with "You cannot reply to this topic" when I look at it.
Assume something got screwed up in the transfer to the new site, there were some posts which went missing too.
Can only suggest you start another thread called "Ubuntu 14.04.1 linuxcnc help - continued" and cross reference to the original thread.
When you have done that I will edit my last entry, which apparently I can still do, and cross reference there too
The following user(s) said Thank You: Razor_keen
- jepler
- User is blocked
- Thank you received: 33
14 Nov 2015 13:43 #65241
by jepler
Replied by jepler on topic Why can't I reply in my own topic?
There was an error with the permission setting on several categories, including the one containing your post. I believe I have corrected the problem.
- Razor_keen
14 Nov 2015 17:12 #65247
by Razor_keen
Replied by Razor_keen on topic Why can't I reply in my own topic?
you have indeed corrected the issue. thank you
Time to create page: 0.221 seconds
