save tool number in var file and load on start
- viski
20 Nov 2015 17:03 #65590
by viski
save tool number in var file and load on start was created by viski
I have automatic tool changer with 12 tools. Every switch represent one tool. What do i have to do ,to save current tool into .var file and to be loaded when emc start , to avoid tool changer indexing(ref) ?
- ArcEye
- Thank you received: 240
21 Nov 2015 05:59 #65596
by ArcEye
Replied by ArcEye on topic save tool number in var file and load on start
At the end of your code run
#4999=#5400
Current tool is already in #5400 but it is volatile
If #4999 is in your var file it will be preserved
Next start up run
M61 Q#4999
#4999=#5400
Next start up run
M61 Q#4999
The following user(s) said Thank You: Shu
- viski
21 Nov 2015 15:37 #65627
by viski
Replied by viski on topic save tool number in var file and load on start
I have found this about parameters:
System Parameters
#<_current_tool> - Return number of the current tool in spindle. Same as #5400.
#4999=#5400
.... can i make assigment in classicladder ?
Where to put M61 Q#4999 into ini file to auto run code?
System Parameters
#4999=#5400
- ArcEye
22 Nov 2015 04:37 #65653
by ArcEye
No idea, but why would you want to, doing it in gcode is simple.
There is no provision in the ini file for that.
You could put the code in one of the ini file halui MDI strings and connect via a flipflop say to the last homed of your axes
via the haui.axis.N.ishomed, so that the tool would be set when you home all axes for the first time.
Time to create page: 0.206 seconds
