Debian Wheezy =>error: python: nv04_state_raster.c
- jtc
- Thank you received: 12
24 Nov 2015 18:40 - 24 Nov 2015 20:01 #65752
by jtc
Debian Wheezy =>error: python: nv04_state_raster.c was created by jtc
Hi.
after a clean RIP install of linuxcnc configured to uspace, I try to run a sample configuration, but I get this error:
This installation runs on Debian Wheezy, in a old P4 32bit.
João
edited:
looks like is a graphics related problem
forum.linuxcnc.org/forum/9-installing-li...ttempting-to-run-emc
I will try with onboard graphic card tomorrow.
jtc@jtctech:~$ uname -r
3.2.0-4-rt-686-pae
jtc@jtctech:~$ ./linuxcnc-dev/scripts/linuxcnc linuxcnc-dev/configs/sim/axis/axis_9axis.ini
LINUXCNC - 2.8.0~pre1
Machine configuration directory is '/home/jtc/linuxcnc-dev/configs/sim/axis'
Machine configuration file is 'axis_9axis.ini'
Starting LinuxCNC...
Found file(lib): /home/jtc/linuxcnc-dev/lib/hallib/core_sim9.hal
Note: Using POSIX realtime
Found file(lib): /home/jtc/linuxcnc-dev/lib/hallib/sim_spindle_encoder.hal
Found file(lib): /home/jtc/linuxcnc-dev/lib/hallib/axis_manualtoolchange.hal
Found file(lib): /home/jtc/linuxcnc-dev/lib/hallib/simulated_home.hal
Found file(lib): /home/jtc/linuxcnc-dev/lib/hallib/locking_indexer.hal
task: main loop took 0.013007 seconds
task: main loop took 0.012480 seconds
python: nv04_state_raster.c:126: get_blend_func: Assertion `0' failed.
./linuxcnc-dev/scripts/linuxcnc: line 845: 4980 Aborted $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
task: 2244 cycles, min=0.000024, max=0.013007, avg=0.001095, 2 latency excursions (> 10x expected cycle time of 0.001000s)
LinuxCNC terminated with an error. You can find more information in the log:
/home/jtc/linuxcnc_debug.txt
and
/home/jtc/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminalThis installation runs on Debian Wheezy, in a old P4 32bit.
João
edited:
Last edit: 24 Nov 2015 20:01 by jtc.
- jepler
- User is blocked
- Thank you received: 33
24 Nov 2015 22:47 #65756
by jepler
Replied by jepler on topic Debian Wheezy =>error: python: nv04_state_raster.c
I believe you're right that it's graphics-driver specific. I don't believe it indicates a bug in LinuxCNC, but the OpenGL driver. I added a longer note about this in the topic you linked to.
The following user(s) said Thank You: jtc
- jtc
25 Nov 2015 13:02 - 25 Nov 2015 13:37 #65772
by jtc
I have to say that I only had this problem after pass from rtai kernel to rt kernel.
anyway, this command from the wiki solve it:
João
Replied by jtc on topic Debian Wheezy =>error: python: nv04_state_raster.c
sudo apt-get install libgl1-mesa-swx11João
Last edit: 25 Nov 2015 13:37 by jtc.
Time to create page: 0.198 seconds
