linuxcnc remap g88.6 using python
- crazyboywang
25 Nov 2015 05:07 #65765
by crazyboywang
linuxcnc remap g88.6 using python was created by crazyboywang
ini setting
[DISPLAY]
PROGRAM_PREFIX=/home/wzc/linuxcnc/nc_files
[RS274NGC]
REMAP=G88.6 modalgroup=1 argspec=XYZp python=g886
put the "g886.py" to the directory "/home/wzc/linuxcnc/nc_files"
chmod +x g886.py
g886.py code is
from interpreter import INTERP_OK
from emccanon import MESSAGE
def g886(self, **words):
for key in words:
MESSAGE("word ’%s’ = %f" % (key, words[key]))
if words.has_key(’p’):
MESSAGE("the P word was present")
MESSAGE("comment on this line: ’%s’" % (self.blocks[self.remap_level].comment))
return INTERP_OK
when run the linuxcnc , promoted " 'g886' is not a python callable function -81 REMAP=g886........ "
[DISPLAY]
[RS274NGC]
chmod +x g886.py
g886.py code is
for key in words:
return INTERP_OK
- ArcEye
- Thank you received: 240
25 Nov 2015 07:17 #65767
by ArcEye
Replied by ArcEye on topic linuxcnc remap g88.6 using python
I see you have posted all over the Machinekit forum with this too.
It is no good telling us what is in the file, you need to attach it.
What you have posted would not run, need to see the actual file header, indentations etc etc
