Joints_Axis9 Update Script?
  • Todd Zuercher
  • Todd Zuercher's Avatar Topic Author
  • Platinum Member
  • Platinum Member
03 Dec 2015 16:23 #66287 by Todd Zuercher
Joints_Axis9 Update Script? was created by Todd Zuercher
I installed Joints_Axis9 on a virtual machine to try to test some things out (Mint 17 is the OS). However when I try to run update_ini script on one of my configs all I get is a command not found?
todd@todd-VirtualBox ~/linuxcnc/configs/Dig5 $ ls
custom.hal              Dig5.hal      linuxcnc.var.bak      README
custompanel_backup.xml  Dig5.ini      parport.2.pin-02-out  tool.tbl
custompanel.xml         Dig5.ini.bak  parport.2.pin-03-out  update_ini
custom_postgui.hal      linuxcnc.var  postgui_backup.hal
todd@todd-VirtualBox ~/linuxcnc/configs/Dig5 $ update_ini Dig5.ini
update_ini: command not found
Any ideas why the script won't work?
03 Dec 2015 16:34 #66290 by andypugh
Replied by andypugh on topic Joints_Axis9 Update Script?
How did you get it? If you compiled, did you run the rip-environment script?
  • Todd Zuercher
  • Platinum Member
  • Platinum Member
03 Dec 2015 17:33 - 03 Dec 2015 17:35 #66300 by Todd Zuercher
Replied by Todd Zuercher on topic Joints_Axis9 Update Script?
I installed it using some of the instructions in one of the other Linuxcnc Mint topics here.
I was able to make it work now, I manually copied the update_ini script file into usr\bin\, and then it worked.
I wasn't running it as a rip. I suspect if I had been it probably would have just worked.
Last edit: 03 Dec 2015 17:35 by Todd Zuercher.
Time to create page: 0.093 seconds
