Keeping G43/TLO enabled, also after error
- DaBit
- Thank you received: 19
04 Dec 2015 23:01 #66420
by DaBit
Keeping G43/TLO enabled, also after error was created by DaBit
Is there a method to keep G43 enabled until explicitly disabled with G49?
From time to time an error occurs, LinuxCNC (or gmoccapy) disables tool length compensation, and when I forget to re-enable G43 the tool crashes into the workpiece when using MDI to get back to the right coordinates. I can also avoid this by making tool lengths negative, but I'd rather have G43 as persistent as possible.
I tried the 'Retain G43' bit in [RS274NGC]FEATURES. I have no idea what that is supposed to do, but when I enter G43 in MDI the DRO changes as it should, but when I execute a G0X0Y0 in MDI the G43 is canceled?
- Rick G
- Thank you received: 114
05 Dec 2015 08:04 #66443
by Rick G
Replied by Rick G on topic Keeping G43/TLO enabled, also after error
www.linuxcnc.org/docs/2.6/pdf/LinuxCNC_Integrator_Manual.pdf
Rick G
Retain G43:1 (experimental)
When set, you can turn on G43 after loading the first tool, and then not worry about it through the program. When you
finally unload the last tool, G43 mode is canceled. This is experimental as it changes the operation of legal ngc program,
but it could be argued that those programs are buggy or likely to be not what the author intended
Rick G
- DaBit
05 Dec 2015 10:19 #66445
by DaBit
Replied by DaBit on topic Keeping G43/TLO enabled, also after error
That options does not work as expected, see start post. LinuxCNC 2.8~pre BTW.
- Rick G
05 Dec 2015 14:27 #66455
by Rick G
Yes I saw that, just posted the link as a stating point. I first thought of M70-M72 but you would still have to enter them.
Rick G
Rick G
- DaBit
08 Dec 2015 08:44 #66613
by DaBit
It would be a very dirty hack, but would it be possible to run a script that does something like this:
while (1) {
if (current_tool != 0 && linuxcnc.mode != auto) {
issue_mdi_command ("G43");
sleep (1);
That would break a few things such as G43.1 etc., but I am not using those anyway.
Is that something the Pyton bindings would allow me to do? Maybe then I finally have a reason to learn Python.
while (1) {
sleep (1);
Time to create page: 0.229 seconds
