Estop on Smithy CNC622
- dgrenier67
08 Dec 2015 18:16 #66637
by dgrenier67
Estop on Smithy CNC622 was created by dgrenier67
Hi, I'm trying to update my Smithy 622 (Mesa 5i20 Ctrl) with LinuxCNC over Debian (direct image files). This machine works well with EMC2 2.3.5 and Ubuntu 8.04.
My first problem is that the machine still in EStop mode at startup, even with my reset sequence (key-off / RESET push button / key-on). I see my machine key switch toggling in HAL monitoring, but I can't figure the rest of logic to go further.... any ideas?????
I'm using the 622.hal and 622.ini configuration.
Thanks everyone!!!!
Thanks everyone!!!!
- BigJohnT
- Thank you received: 994
09 Dec 2015 12:57 - 09 Dec 2015 12:59 #66678
by BigJohnT
Why are you trying to upgrade if the machine works well? It's quite possible that the older PC runs better on older OS.
Did you follow the upgrade path from 2.3 to 2.7?
linuxcnc.org/docs/2.6/html/common/Updating_LinuxCNC.html
linuxcnc.org/docs/2.7/html/getting-start...dating-linuxcnc.html
JT
Replied by BigJohnT on topic Estop on Smithy CNC622
JT
Last edit: 09 Dec 2015 12:59 by BigJohnT.
- cncbasher
- Thank you received: 202
09 Dec 2015 13:24 #66679
by cncbasher
Replied by cncbasher on topic Estop on Smithy CNC622
with transferring from such an older version , it is highly possible some naming conventions have changed or replaced
archive your config and attach , and we can take a look , rather than muddle through finding them .
it's also likely you may need to adjust some timings , so just be aware
Time to create page: 0.232 seconds
