Remap G74 using online example
  • emcPT
  • emcPT's Avatar Topic Author
  • Platinum Member
  • Platinum Member
08 Dec 2015 21:05 #66641 by emcPT
Remap G74 using online example was created by emcPT
Hello, first try here about the REMAP capability, and using the already existent G74 remap code on:
wiki.linuxcnc.org/cgi-bin/wiki.pl?G74_-_...illing/Face_Grooving
When I run a test code I get the following error:
Bug: Call stack underrun
Exactly what I did (using LinuxCNC 2.6.x):
1) Added to my INI file under the correct sections what is on the above web page
2) Created a folder in my config directory named 'python'
3) Created 2 files in that directory: toplevel.py and remap.py, both with the contents that is described on the page above
Am I missing something obvious? The error result (Bug: Call stack underrun) is not clear.
Thank you
09 Dec 2015 12:41 #66677 by BigJohnT
Replied by BigJohnT on topic Remap G74 using online example
The big question is which of the 3 examples did you try?
JT
  • emcPT
  • Platinum Member
  • Platinum Member
11 Dec 2015 06:41 #66794 by emcPT
Replied by emcPT on topic Remap G74 using online example
I was using the python example (first one).
Did exactly the same thing on the latest stable linuxcnc version and it worked out fine, so no more problems.
Time to create page: 0.153 seconds
