Drive options for steppers with encoders?
- JimS
11 Dec 2015 16:47 #66835
by JimS
Drive options for steppers with encoders? was created by JimS
Have a very small mill that was fitted with steppers with 500 line encoders. Need to get motor drives. What are the options for controls that won't break the bank that are compatible with linuxcnc?
- Thank you received: 1469
11 Dec 2015 17:58 #66837
Replied by Todd Zuercher on topic Drive options for steppers with encoders?
Steppers don't usually have encoders, are you sure that is what they are?
What are the motor specs?
What size are the motors? How much current are they rated for?
- JimS
11 Dec 2015 18:46 #66845
by JimS
Replied by JimS on topic Drive options for steppers with encoders?
The motors are clearly labeled (with the OEM label) "1.8 degree step motor" from Compumotor, OS series. Current rating is 3.7A. Encoders are 512 line HP/Agilent/Avago (they have changed names several times) encoders. I wasn't able to find the exact specs of this motor on the Compumotor site - it may have been custom or custom labeled. The encoder mounting looks to be a factory job. I could just run them open look but was wondering what it would take to use the encoders. The motors were retrofitted to the mill I have - the work was well done but clearly a retrofit. I need to put together the motor control and am wondering if the motors are big enough for the machine. You can see the machine here:
- JimS
11 Dec 2015 18:48 #66846
by JimS
Guess I can't post links yet....
It's on cnczone site at forums/benchtop-machines/282060-servo-products-cnc-mill.html
- BigJohnT
- Thank you received: 994
12 Dec 2015 22:30 #66896
by BigJohnT
Replied by BigJohnT on topic Drive options for steppers with encoders?
I think your first 3 posts are moderated to keep out spammers.
JT
JT
- Thank you received: 2173
13 Dec 2015 04:36 - 13 Dec 2015 05:05 #66920
Replied by cmorley on topic Drive options for steppers with encoders?
compumotor had step drives that used encoders. They were still step/direction dives and can easily be used with linuxcnc.
I have one i believe its a S6 or SX6 drive (i dont use encoders) they use special motors (110 volt)
compumotor also had serial interface IFAIK but I doubt the machine came with that.
Chris M
s6 is the step drive, sx6 is an indexer (you don't want that)
Chris M
Last edit: 13 Dec 2015 05:05 by cmorley.
- Shalotek
13 Dec 2015 04:38 #66921
by Shalotek
Replied by Shalotek on topic Drive options for steppers with encoders?
the cheapest i could find was PICO-systems USC and i am using longs motors steppers and drives from Ebay
Here is a link so you can see my machine for reference
www.youtube.com/channel/UCiRqg_iQ-jsIcW1eX6On6hw
Time to create page: 0.349 seconds
