ngcgui preamble postamble
  • Rick G
  • Rick G's Avatar Topic Author
  • Junior Member
  • Junior Member
17 Dec 2015 12:48 #67086 by Rick G
ngcgui preamble postamble was created by Rick G
One of the neat features of NGCGUI is that you can string together several subs before you finalize.
You can select a preamble to run just once with the "features" parameter.
So your preamble could start the spindle with a M3 or call a sub to light a plasma torch.
And not be repeated for the remaining subs.
You can also select a postamble to run at the end, such as a M5.
However it appears that the postamble runs at the end of each sub not just the last one.
Is there a parameter to avoid this?
Rick G
17 Dec 2015 13:37 #67087 by dgarrett
Replied by dgarrett on topic ngcgui preamble postamble
I think you are referring to the #<_feature> global that is incremented for each feature.
ngcgui inserts a special global variable named #<_feature:> that begins
with a value of 0 and is incremented for each added feature.  This
_global can be tested in subroutines; no entry box is created for it.
There is no such parameter but you could:
1) Make a subroutine that does what you want (M5.ngc for example) and invoke
it as the last subroutine in the chain
or
2) Use a 'custom' tab, specify a final subroutine (no-op.ngc if necessary),
specify a final postamble in the tab, invoke this subroutine last in the chain.
(A custom tab is specified with NGCGU_SUBFILE="")
or
3) Use the option "NGCGUI_OPTIONS=noiframe and manually specify a different
postamble for the last subroutine in the chain
The following user(s) said Thank You: Rick G
  • Rick G
  • Junior Member
  • Junior Member
17 Dec 2015 14:03 #67089 by Rick G
Replied by Rick G on topic ngcgui preamble postamble
dgarrett,
Yes, I was away from the computer.
I have used both 1 and 2 above in the past, but it would nice to have something more automatic.
Again thanks for your work on NGCGUI!
Rick G
17 Dec 2015 17:01 - 17 Dec 2015 18:45 #67093 by dgarrett
Rick,
I made a patch that causes (py)ngcgui to create a global that
can be tested in the subroutine (or the preamble or postamble):
#<_last_feature:> == 1 if last feature, 0 otherwise
The tar file includes the patch and updated ngcgui.tcl, pyngcgui.py:
www.panix.com/~dgarrett/stuff/last_feature.tgz
If you test both files and this fix meets your needs, i would make
a commit to put it in git master.
Note: if a subroutine that tests this variable is used in other
contexts (e.g., not ngcgui), it should test first for the existence
of the variable using the EXISTS[arg] function
ref: linuxcnc.org/docs/2.7/html/gcode/overview.html#gcode:functionsj
Last edit: 17 Dec 2015 18:45 by dgarrett.
17 Dec 2015 20:53 - 17 Dec 2015 21:16 #67103 by dgarrett
Rick,
I had a better idea and made a new patch for a more general solution:
www.panix.com/~dgarrett/stuff/remaining_features.tgz
With this version, the global variable created is a count of the
number of features remaining after the current feature:
#<_remaining_features:>
So a value of zero indicates the current feature is the last.
You could also use it to print the number of features remaining.
Last edit: 17 Dec 2015 21:16 by dgarrett.
  • Rick G
  • Junior Member
  • Junior Member
18 Dec 2015 07:26 #67123 by Rick G
Dewey,
That is great! Just tried it on ngcgui with no postamble and I think it is a great new feature.
For example I edited slot.ngc by adding...
;adding to test remaining features
(debug, remaining features, #<_remaining_features:>)
o<i3> if [#<_remaining_features:> EQ 0]
        m5
        (debug, m5 last remaining features, #<_remaining_features:>)
o<i3> endif
As you said with this you get a running count down on the screen of the features that are running and a action to be taken after the last feature.
Thanks for the great addition.
Rick G
18 Dec 2015 13:49 #67129 by dgarrett
ok -- pushed to master, thanks for the suggestion
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...2e28958f6e440f00dd65
Time to create page: 0.220 seconds
