About RTCP questions
- 819132306
26 Dec 2015 11:02 #67337
by 819132306
About RTCP questions was created by 819132306
Hi everyone!
My English is not good, I am Chinese.
I'm a DIY fan
I want to configure a five-axis linkage machine tool.
Machine tool structure is as follows:
X Y Z A(Rotary table) B(rotary head)
If I want to have RTCP function.
Do I need to modify the 5axiskins.c?
"5 axiskins. C" is for "XYZBC"?
How to switch RTCP mode?
Look at this:
Hope to have help
Lee
I'm a DIY fan
Look at this:
Hope to have help
Lee
- Thank you received: 4654
26 Dec 2015 12:05 #67339
That's called "World Mode". There is a menu option on the Axis interface, or you can use the $ shortcut (not helpful if your keyboard doesn't have "$").
You can't switch to World mode in Touchy. I am not sure about other interfaces.
Replied by andypugh on topic About RTCP questions
It might just work as it is.Do I need to modify the 5axiskins.c?
- 819132306
26 Dec 2015 12:58 #67340
by 819132306
Thank you!
andy
Do I need to build a similar 5 axiskins. C file?
Whether can run on the G code when switching the world mode?
Replied by 819132306 on topic About RTCP questions
Thank you!
andy
26 Dec 2015 14:01 #67344
It is a simple change to the HAL file you just change "trivkins" to"'5axiskins"
(A non-trivial kinematics is one where there is not a 1:1 correlation between a G-code axis word and a motor position)
Have you tried to use the existing 5axiskins file?Do I need to build a similar 5 axiskins. C file?
Yes, you need to be in World (XYZ] mode before you can run G-code when using a non-trivial kinematics.Whether can run on the G code when switching the world mode?
- 819132306
27 Dec 2015 12:28 #67370
by 819132306
"5axiskins" can support arbitrary structure of five-axis machine tools?
27 Dec 2015 13:20 #67372
No. But are you sure that your machine isn't the same as the machine that the kinematics was written for?
- 819132306
28 Dec 2015 13:53 #67398
by 819132306
Andy,
I want to write kinematics on my own.
Do you have a tutorial or information on this?
Thank you,
Andy,
29 Dec 2015 02:08 #67430
All there is is the manual:
linuxcnc.org/docs/2.7/html/motion/kinematics.html
- 819132306
29 Dec 2015 13:08 #67451
by 819132306
Thank you
Time to create page: 0.103 seconds
