Linuxcnc Disapeared
- wl888
31 Dec 2015 05:26 #67585
by wl888
Linuxcnc Disapeared was created by wl888
linuxcnc 2.7.0
Further to my previous post, I just restarted the computer and there is now no sign of the Linuxcnc shortcut, nothing to start it in the applications/cnc drop-downs. the other linuxcnc stuff is there.
went to do an edit on the existing ini or whatever file and it 's not there.
is the a file that i can hard load onto the drive so that i don't have to use a disc or redo the setup every time i run it.?????
this has not been a great intro to linux.,
HELP!!!!!!!!!! please
Doug
Doug
- Thank you received: 4654
31 Dec 2015 15:00 #67597
Replied by andypugh on topic Linuxcnc Disapeared
This is very strange.
Does LinuxCNC try to start if you type "LinuxCNC" in a terminal window?
(You can open a terminal from the "accessories" menu.)
This will show if LinuxCNC has been randomly uninstalled (I have no idea why that might happen)
- BigJohnT
- Thank you received: 994
31 Dec 2015 21:37 #67616
by BigJohnT
Replied by BigJohnT on topic Linuxcnc Disapeared
How did you install LinuxCNC?
JT
JT
- wl888
31 Dec 2015 23:09 #67627
by wl888
Replied by wl888 on topic Linuxcnc Disapeared
BigJohnT and Andypugh
thanks for thew reply
(How did you install LinuxCNC?)
from disk created from "linuxcnc-2.7. wheezy
(Does LinuxCNC try to start if you type "LinuxCNC" in a terminal window?)
Yes, but it takes me to a "configuration selector page....my previously saved config file does not appear here....when i select a cofig the program starts.
It appears that the shortcut is being deleted when i exit linux.
I cannot start linux without the dvd in place, surely there is a way to hard mount linuxcnc onto the hard drive, i just don't know how.....
The version i have was listed as 2.7.3 but is in fact 2.7.0 .....where do i get the 2.7.3 version please.
Doug
Doug
31 Dec 2015 23:13 - 31 Dec 2015 23:14 #67628
It sounds like you are booting from the DVD. In this mode there is no change made to the Hard Drive, so configs don't get saved.
When you boot from the DVD there should be a menu giving the option to install Linux, either graphically or at the command line. Graphically it probably to be preferred.
Or have you already done that?
Note that installing from the DVD will wipe the hard drive and remove the existing OS. Be sure that is what you want to do.
Last edit: 31 Dec 2015 23:14 by andypugh.
- wl888
01 Jan 2016 00:38 #67633
by wl888
Andy/JT
OK...now can boot without a disc....THANK YOU !!!
also can now login...as with many people got confused with what login was asking for ...now sorted...also have now been presented with 75 updates including the one for linuxcnc..now downloading/installing them all.
havn't got any further at this stage
being a nube to the forum i have posted 2 questions that for ease i will now only be acting on one...please see
"TOPIC: Linuxcnc 2.7.? Wheezy loads but wont drive"
thanks for your help
hopefully with the updates i will be able to continue.
Doug
Doug
Time to create page: 0.278 seconds
