HAL in Python getprefix() and setprefix() Usage?
03 Jan 2016 14:53 #67753 by Simpson36
newbee here struggling to read existing pins using Python and/or just loading a python program into LinuxCNC.
the hal component for python states that any pins can be accessed, but it will not allow you to use an existing name for the hal.component and if you use an existing name for the pin you want to access, it says 'undefined.
From this behavior, I assume that the pin prefix and the hal.component names have to match.
There are commands (methods?) for getting and setting the prefix. They seem to work, but I cannot figure out how to use them. I've done numerous searches, but just keep coming up with the same document that mentions the commands, but gives no clue on how to use them.
03 Jan 2016 16:18 #67760 by ArcEye
..............the hal component for python states.............
You need to tell us exactly what you have been reading ( a link to it ) and as importantly, exactly what you are trying to do.
There are lots of orphaned wikis and old html pages out there, we can't guess what you have stumbled upon, or whether what you have read is relevant or applicable to what you are trying to do.
03 Jan 2016 19:36 #67767 by cmorley
So Just guessing what info you need.
This shows you how set_prefix works.
The component will be loaded by and called passthrough but
the pin names are pt.in and pt.out
The prefix change needs to be done before any pins are made.
!/usr/bin/python
import hal, time
h = hal.component("passthrough")
h.set_prefix('pt')
h.newpin("in", hal.HAL_FLOAT, hal.HAL_IN)
h.newpin("out", hal.HAL_FLOAT, hal.HAL_OUT)
h.ready()
try:
    while 1:
        time.sleep(1)
        h['out'] = h['in']
except KeyboardInterrupt:
    raise SystemExit
03 Jan 2016 19:43 #67768 by cmorley
The docs may be stale a bit.
Depending on the linuxcnc version there are other functions available:
FUNCTIONS
    component_exists(...)
        Return a TRUE value if the named component exists
    component_is_ready(...)
        Return a TRUE value if the named component is ready
    connect(...)
        connect pin to signal
    get_msg_level(...)
        Get the RTAPI message level
    new_sig(...)
        create a signal
    pin_has_writer(...)
        Return a FALSE value if a pin has no writers and TRUE if it does
    set_msg_level(...)
        Set the RTAPI message level
03 Jan 2016 22:34 #67786 by Simpson36
Replied by Simpson36 on topic HAL in Python getprefix() and setprefix() Usage?
I am trying as best I can to explain the process, and I am very thankful for all of the time everyone is spending trying to help, but the solutions only address a specific pieces of the puzzle and not the overall task. So the instruction on how to create pins is great and the suggestion on how to net them is great and the suggestion of how to use Glade actions is great, but none of these will do the whole job, because none will create and net and read and write multiple pins.
In a nutshell, I want to be able to create, and then read and write ANY pin under program control using a language that can also do math, conditional statements and also (I never got this far before, but may as well throw it out there) the ability to manipulate disk files.
So far as I can determine at this point, all of that exists, but not in any one form. You need Python HAL to create pins, then another method to net the pins and the Python program that creates and manipulates the pins won't load automatically and has to load before the hal program that nets the pins, and so on. It's like you can't get there from here. I am hoping that I'm just being dense and not understanding something.
I do appreciate everyone being patient and trying to figure out what the heck I'm taking about :kiss:
03 Jan 2016 22:56 #67787 by Simpson36
FUNCTIONS
    connect(...)
    get_msg_level(...)
    new_sig(...)
        create a signal
    pin_has_writer(...)
    set_msg_level(...)
The documents that I am using are on LinuxCNC.org
If this is the 'linuxCNC' library, then I think the docs are out of date as I don't recall seeing any functions having to do with pins at all . . and I looked for them.
Where can I find the current documentation on the LinuxCNC library for Python? If linking/netting has been added then the combination of the 'hal' and the 'LinuxCNC' would create the pins and then 'net' them. That's not the entire pie, but a lot more than I know about so far! And it's all Python, so trying to get the Python to run first and then another HAL file afterward would be eliminated. :cheer:
The majority of the device communicates with LinuxCNC via a pair of macros. One macro covers all 48 Modbus coils and the other covers all 35 Modbus registers (a.k.a. 'holding'). These are written in BASH which has direct access to all of the pins, including the Modbus pins and also the specially prefixed pins created by PyVCP. This was uber easy to do and has me thinking that BASH may be the better solution.
There is also apparently a Python 'plug-in' that has yet another different set of capabilities which I have not looked at yet.
My suggestion, just based on what I can determine at this point would be to recruit the talent to add the pin access that bash has to the 'linuxCNC' library which has everything BUT access to the pins. It seems at least that some of that may have been done already. I need to get my hands on the current docs for the 'LinuxCNC' library.
Where can I find that?
03 Jan 2016 23:11 #67788 by Simpson36
FUNCTIONS
    connect(...)
    get_msg_level(...)
    new_sig(...)
        create a signal
    pin_has_writer(...)
    set_msg_level(...)
I thought these were new stuff added to the 'linuxcnc' library for python, bit it does not appear that's the case.
What library are these from?
03 Jan 2016 23:22 #67789 by Simpson36
!/usr/bin/python
import hal, time
h.set_prefix('pt')
h.ready()
try:
    while 1:
        time.sleep(1)
        h['out'] = h['in']
    raise SystemExit
#!/usr/bin/python
import hal, time
h.ready()
try:
while 1:
time.sleep(1)
h = h
raise SystemExit
Above is what is on LinuxCNC.org, so there must be more current stuff somewhere.
What is the best place to look for the most up-to-date documents?
As far as get/setprefix, given the way you describe the usage, it will not be useful in accessing existing pins, which was my hope.
04 Jan 2016 09:26 - 04 Jan 2016 09:27 #67806 by ArcEye
I still have no idea what you are doing, aside from a passing confused reference to modbus.
The python bindings which constitute 'the library' as you call it are written in quasi C++
They are at
src/hal/halmodule.cc
src/emc/usr_intf/axis/extensions/emcmodule.cc
for the most part
These locations refer to the source code, which you will need to download
github.com/LinuxCNC/linuxcnc
The docs are mostly
linuxcnc.org/docs/2.6/html/common/python-interface.html
linuxcnc.org/docs/html/hal/halmodule.html
wiki.linuxcnc.org/cgi-bin/wiki.pl?Using_HAL_In_Python
The whole need / use for getprefix() and setprefix() is not clear to me in any case.
A pin prefix is always that of the owning component by default, if you want to interrogate values of existing pins etc that is completely different.
Look at find_item() to start with, in halmodule.cc
Last edit: 04 Jan 2016 09:27 by ArcEye.
04 Jan 2016 10:03 #67807 by cmorley
These are from the HAL python library. there are no docs on them aside from reading the python module.
I knew they were there because I added a couple of them and have read the source code.
They have been there a long time so if you are using 2.6 or better they will be there.
in a terminal type
python <return>
then type
import hal <return>
then type
help(hal) <return>
keep scrolling down with the cursor keys
pressing q will get you back
Chris M
The following user(s) said Thank You: Simpson36
Time to create page: 0.203 seconds
