home switch configuration
07 Jan 2016 22:46 #68034 by JohnK43
home switch configuration was created by JohnK43
Again thanks to all. The foam config foam wire cutter is up and working. I tried to set the home axis sequence in stepconfig
and could not figure it out. Manually editing the .ini file resulted in the desired behavior.
The sequence to home now is x,y,u,v. Is it possible to set this sequence from step config? all the home switches are wired in series.
Thanks again in advance
08 Jan 2016 03:52 #68051 by kornphlake79
Replied by kornphlake79 on topic home switch configuration
You can't specify the homing sequence using stepconfig, you didn't miss anything, the option isn't there. Editing the .ini didn't seem too painful to me.
08 Jan 2016 13:43 #68062 by JohnK43
Replied by JohnK43 on topic home switch configuration
Thanks I thought maybe I missed something. I will probably just edit the .ini file in the future. I have been doing most of the changes
using stepconfig. I don"t have a problem doing it by editing it by hand . It is not a big deal.
Time to create page: 0.162 seconds
