New - Grinder Lightyears behind
- cyrut2
Ive been using linuxcnc for a couple days now finally got the steppers to run okay. Its odd but its runs somether than GRBL but at high rpms GRBL was able to get the IPM high than Linux cnc. Played with alot of things timing and hardware noise etc but still havent achieved what i think is good.
I am applying this to a grinder so care must be taken thats why i shy away from GRBL. High rpm with large loads is nothing to play with a 35 dollar arduino. Linux seems safer but i am nowhere near where i want to be on the learning curve of PLC Classic and using a china board. I have two axis the idea i had was to write in PLC where i can get a couple inputs that depending on how they were pushed would give different outcomes like binary. I want to advance the stepper x amount as if a command in g code. Kinda like a MPG but with buttons -foward back a millionth, thousand kinda thing. Can this simply be done? I still dont understand how to create PLC Logic reading but not understanding.
Ive though of purchasing a mesa ethernet but as i look it seems like im far behing is there a ethernet setup that would be easy to get up and running without alot of hal editting? The problem is that the machine is very large with high voltage creating alot of noise if i can get a ethernet isolated externally to control this would simplify the installation.
Thanks in advance for any tips
My guess is that you are running out of step rate with software stepping.Ive been using linuxcnc for a couple days now finally got the steppers to run okay. Its odd but its runs somether than GRBL but at high rpms GRBL was able to get the IPM high than Linux cnc. Played with alot of things timing and hardware noise etc but still havent achieved what i think is good.
You can increase the step rate whilst retaining the parallel port as the communications mode by using either a Pico PPMC ( pico-systems.com/PPMC.html ) or the Mesa 7i90-HD ( store.mesanet.com/index.php?route=produc...83_85&product_id=291 )
Yes, this can be done. It sounds like you don't want to have a PC monitor and PC Display?
Do you actually want to run G-code, or just move stepper motors by fixed amounts?
- cyrut2
I have to profile the grinding wheel to match the part which is when i need the g code to run the diamond across the wheel. The easy part is having the slide go in and out to put pieces into the infeed system. Once running buttons are usually what makes the process simple since you need to adjust for the wear of the wheel which gets smaller as you run. Its never the same part to part thats why manual buttons seem more pheaseable.
It is quite likely that Pncconf does not know about the 7i90. A 7i43 config might get you close, then some hand-editing of the config files.I go to the pncconf and it seems that the parport card is not there. It shows 5i25 but i can find the 7i90.
You would need to use the special 7i90 driver rather than the 7i43 one:
linuxcnc.org/docs/2.7/html/man/man9/hm2_7i90.9.html
It is driven at the servo thread rate, but between updates can output steps at MHz frequencies.Does this card take the servo thread so i can bump up the frequency?
- Thank you received: 7488
Tom
Oh, hi Andy!
PnCconfig is for mesa cards, stepconf is for parallel port.
And Pncconf is for Mesa cards connected to the parallel port...
- cyrut2
Im going to buy the 7i90 since its cheap and affordable then ill later get into the ethernet stuff. I want to get started with steppers although i have alot of 3kw to 1kw servos collecting dust (Fanuc). Can the 7i90 also work with encoder servo stuff. Im going to start with 3 steppers with 4k encoders, MPG as input and about 10 ins and 7 outs, servo that needs 3 pwm from pico (this is to play with). Can you recommend what i need to get from mesa? The pico stuff is because i cant find any large servo drives in stock from mesa. Besides i need the fanuc convertor from pico to get those servos going. Graduating this year so i have no experience in electrical field.
With a change of firmware and interface boards, yes.Can the 7i90 also work with encoder servo stuff.
you would simply flash with a servo-biased firmware. The software download has quite a range of firmwares (you would use 7i90_epp*.bit files). In the bitfile names st means stepper, sv is servo, ss is smart-serial. However you need to look in a little more detail to figure out the specific pin-allocations.
It is possible to convert Fanuc gray-code to a range of alternative commutation encoding styles using the "bldc" HAL component.Besides i need the fanuc convertor from pico to get those servos going. Graduating this year so i have no experience in electrical field.
Thank you Andy for enlightening me on that, i realy do not remember seeing paraport mentioned in the PnCconfig, although i just had a look at it once when it first came to Linucnc.
You can choose a 7i43 and it lets you configure the parport address. It doesn't seem to know about the others yet.
