MITSUBISHI MR-2JS can be controlled by parallelpor
- dex
15 Jan 2016 01:01 #68426
by dex
MITSUBISHI MR-2JS can be controlled by parallelpor was created by dex
hi
would anyone know if the mitsubishi servo amplifer drive
mr-j2s can be controlled by linuxCNC using prallel port directly?
im new to this.
but i have the manual.
there seems to be some data on:
3.3.2 Signal explanations
For the I/O interfaces (symbols in I/O division column in the table), refer to section 3.6.2.
In the control mode field of the table
thanks for any help.
im new to this.
- Thank you received: 2181
15 Jan 2016 01:52 #68429
Replied by cmorley on topic MITSUBISHI MR-2JS can be controlled by parallelpor
posting the manual if you can, would help, or quoting more of the specifications.
+-10volt amps are easy to use.
step and direction amps are easy
anything else is much harder.
Chris M
Chris M
15 Jan 2016 12:54 #68447
Replied by andypugh on topic MITSUBISHI MR-2JS can be controlled by parallelpor
It appears to offer step-dir position control. Some sort of break-out board to protect the parport might be wise.
Time to create page: 0.200 seconds
