Newbe - LinuxCNC or Mach3
17 Jan 2016 21:44 - 17 Jan 2016 21:45 #68622 by Rick G
Last edit: 17 Jan 2016 21:45 by Rick G.
The following user(s) said Thank You: caprio
18 Jan 2016 18:13 #68703 by caprio
Replied by caprio on topic Newbe - LinuxCNC or Mach3
Hmmm, So outta the box fresh install and update of LinuxCNC 2.7.3 I'm seeing latency of:
Servo 42237(ns)
Base 26936(ns)
Not even close to what some of you are reporting (15000, 8000)
I'm using an ATI X1300
I tried the isolcpus and irqbalance tricvks by adding the kernel options but that didn't work well.
The Latency actually jumped to 46910(ns) . After a bit more research it appears that isolcpus is
no longer needed/used.
18 Jan 2016 18:22 #68706 by andypugh
Replied by andypugh on topic Newbe - LinuxCNC or Mach3
Servo 42237(ns)
Base 26936(ns)
That will do. It's not spectacular, but it is quite good enough.
18 Jan 2016 18:27 #68707 by Ozcnc
Replied by Ozcnc on topic Newbe - LinuxCNC or Mach3
Before I got some tweaking going I was sitting at 75000 with spikes taking it up to 150000.
But mine wasn't usable.
Time to create page: 0.168 seconds
