latency 2.7.2 install on Raspberry Pi
31 Mar 2016 21:41 - 05 Apr 2016 16:56 #72501 by tjmarch
Replied by tjmarch on topic latency 2.7.2 install on Raspberry Pi
Hey everyone,
Worked with Bananapi M2 to for a while decided to go back to Raspberry Pi2. May someday try some more on BananaPi. But this is what I have going on now. Have created a Raspberry Pi2 image that has 12C, SPI, Serial messaging and Canbus enabled. I will try Canbus interface. Image can be downloaded here.
www.dropbox.com/s/47wuumdfiywowux/login_..._canbus_enabled?dl=0
If you decided to give it a try use this program on a windows machine to write to SDcard
sourceforge.net/projects/win32diskimager/
When selecting image file choose file type *.* , because the name of file is so long and will not show if you look for img file type.
File name is descriptive
login:pi
password:lcnc
If a bigger than 8GB SDcard is used from terminal use
sudo raspi-config
to expand file system
If you give image a try, use from terminal for latency test
latency-histogram --nobase
I have now in my possession the following items
www.microcenter.com/product/431995/Arduino_Mega_2560
microcontrollershop.com/product_info.php...g4sobj2qfh0f4a140gp5
microcontrollershop.com/product_info.php?products_id=4619
A couple of these
www.amazon.com/CAN-BUS-Shield-Compatible...ywords=canbus+shield
And a couple of these
www.microcenter.com/product/431997/Uno_R3_MainBoard
I have allot of soldering to do, should not be to long though.
Will most likely need some pointers in coding
Any suggestions will be greatly received
Tim
Last edit: 05 Apr 2016 16:56 by tjmarch.
Time to create page: 0.093 seconds
