AASD AC Servo controller---newbie question
- orcaz1
15 Jan 2016 18:55 #68485
by orcaz1
AASD AC Servo controller---newbie question was created by orcaz1
Hi! Am I right in assuming that I need to set this motor servo up correctly before I even think about connecting it to a 7i76 daughter board? i.e. set it to speed and analog input etc?
15 Jan 2016 21:50 #68494
Do you have a link to the documentation? It is quite possible that nobody has ever heard of the drive in question.
I am confused by the mention of 7i76 and analog input in the same sentence.
Replied by andypugh on topic AASD AC Servo controller---newbie question
- orcaz1
16 Jan 2016 14:36 #68525
by orcaz1
Replied by orcaz1 on topic AASD AC Servo controller---newbie question
see if this works? www.filedropper.com/2015-v40servodrivertechnicalmanual_1
- cncbasher
- Thank you received: 202
16 Jan 2016 15:19 #68527
by cncbasher
Replied by cncbasher on topic AASD AC Servo controller---newbie question
for servo systems you need the 7i77 daughtercard ,
the servo drives in question are either step/direction or RS485 Serial as well as analog
so quite a few options .
as they have encoder outputs from the drives , the 7i77 card probably would be better suited .
as the 7i76 only has one encoder input .
Time to create page: 0.083 seconds
