- Thank you received: 1480
6i25-7i77 Comunication errors
10 years 9 months ago #68894
Replied by Todd Zuercher on topic 6i25-7i77 Comunication errors
You have my sympathy.
It isn't just new ones that are struggling with this. I've had intermittent problems with it ever since updating to 2.7 (and the smart serial firmware updates that were pushed along with it.)
You don't mention if you've carefully examined your wiring for ground loops.
10 years 9 months ago #68896
Replied by PCW on topic 6i25-7i77 Comunication errors
Todd, did you try the 77f.bit file? if you dont have severe noise issues that may solve the sserial error problem
(until 2.7.4 comes out though, any single error will be fatal))
Also Diederik: did you power cycle your machine after loading the new 77f.bit bitfile?
10 years 9 months ago #68897
No, not yet. The machine (and myself) has been fairly busy lately, and since it mostly only seems to mess up when I hit the e-stop button. I haven't taken the time to mess with it.
10 years 9 months ago #68898
Just tried it and I don't think it made any difference.
Here is what was spit out at the terminal.
Starting LinuxCNC...
Found file(REL): ./Digital_4w.hal
Found file(REL): ./custom.hal
task: main loop took 0.113504 seconds
task: main loop took 0.144979 seconds
task: main loop took 0.100410 seconds
task: main loop took 0.106816 seconds
hm2/hm2_5i25.0: Smart serial card hm2_5i25.0.7i77.0.0 error = (13) Communication error
task: main loop took 0.137305 seconds
hm2/hm2_5i25.0: Smart serial card hm2_5i25.0.7i77.0.0 error = (5) Serial Break Error
hm2/hm2_5i25.0: Smart serial card hm2_5i25.0.7i77.0.0 error = (4) Extra character
hm2/hm2_5i25.0: Smart serial card hm2_5i25.0.7i77.0.0 error = (3) Timeout
hm2/hm2_5i25.0: Smart Serial Error: port 0 channel 0. You may see this error if the FPGA card read thread is not running. This error message will not repeat.
Running HAL shutdown script
task: 5044 cycles, min=0.000034, max=0.144979, avg=0.010256, 5 latency excursions (> 10x expected cycle time of 0.010000s)
File "./timelog.py", line 33, in <module>
time.sleep(delta_t)
KeyboardInterrupt
digital4@digital4-cnc:~/linuxcnc-uvw$
10 years 9 months ago - 10 years 9 months ago #68900
Well if you get a sserial break error, you have a pretty severe noise issue (> 1.4V induced in DB25 cable for longer than 4 usecs)
Is it possible Estop causes a relay/contactor to open which doesn't have arc suppression?
Last edit: 10 years 9 months ago by PCW.
10 years 9 months ago #68901
The e-stop does open a contactor or two, and a few small relays. I could not tell you if they have arc suppression. They are in a separate electrical panel. All I know is I didn't see these problems before 2.7 (not that they weren't there) but the new tool planner is worth putting up with it.
Time to create page: 0.167 seconds
