Could not insert module error
18 Jan 2016 21:44 #68736 by Jake
Could not insert module error was created by Jake
Well I thought I was getting closer.
I am getting this now on startup
Debug file information:
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/hal_ppmc.ko: Operation not permitted
./ppmc_load.hal:25: exit value: 1
./ppmc_load.hal:25: insmod for hal_ppmc failed, returned -1
See the output of 'dmesg' for more information.
6722
  PID TTY      STAT   TIME COMMAND
Stopping realtime threads
Unloading hal components
It all started as I was trying to change some inputs on a few things in the ppmc_io.hal
so I killed that configuration and loaded a new configuration, but am still getting the same error.
Any tips on what I screwed up this time? I am not sure where to go from here as I can not even get it to load with a fresh configuration.
19 Jan 2016 03:08 #68739 by ArcEye
Replied by ArcEye on topic Could not insert module error
Try a reboot, in case the module was not properly unloaded previously
Please attach your hal and ini file, only you currently know what is in them.
After getting this error, do dmesg > dmesg.txt in a terminal and attach that dmesg.txt file too
19 Jan 2016 06:42 #68752 by Jake
Replied by Jake on topic Could not insert module error
I will get that info and post it tonight. I finished getting the LAN cable out there last night, so now I can get the files up on GITHUB
Thanks!
19 Jan 2016 17:28 #68784 by Jake
Here are the files,
Thanks!!
Even with a fresh config after a full shutdown, same error. I made it very mad.
19 Jan 2016 18:17 - 19 Jan 2016 18:32 #68785 by Jake
im going to take the rest of this back to my orginal machine thread instead of muddying up the forum
Last edit: 19 Jan 2016 18:32 by Jake. Reason: deeda deeeee
20 Jan 2016 08:29 - 20 Jan 2016 08:30 #68824 by andypugh
Replied by andypugh on topic Could not insert module error
[  113.830119] PPMC: ERROR: no boards found on bus 0, port 0378
It is failing to find the PPMC board.
Is the parport address right? Is EPP enabled?
Last edit: 20 Jan 2016 08:30 by andypugh.
20 Jan 2016 09:09 #68830 by ArcEye
Andy beat me to it :P
Not in EPP mode looks favorite
[ 113.829923] PPMC: checking EPP bus 0 at port 0378
20 Jan 2016 09:23 #68834 by Jake
Since I dumped the entire config when I got pissed I lost the address setup. The next morning when I woke up I it dawned on me that I never did that. I was pretty pissed at myself as I spent that much time over that.
Time to create page: 0.196 seconds
