7i76E
  • Diederik
  • Diederik's Avatar Topic Author
  • Premium Member
  • Premium Member
19 Jan 2016 16:29 #68765 by Diederik
7i76E was created by Diederik
I also require Sample configuration files or the lines that I need to add to my .hal&.ini files.
I really appreciate the input received on this forum. thanks
20 Jan 2016 14:15 #68819 by andypugh
Replied by andypugh on topic 7i76E
A way to get close is likely to be to create a 5i25/7i76 configuration in PNCConf, then edit the HAL to use hm2_eth instead of hm2_pci.
Some pin names will change, for example I think that the stepgen pins have 5i25 in the name rather than 7i76, but once you have the basic file structure the test is just text editing.
The following user(s) said Thank You: Diederik
20 Jan 2016 19:00 #68844 by newbynobi
Replied by newbynobi on topic 7i76E
does this one help?
Norbert
Time to create page: 1.733 seconds
