Preempt-rt wifi de-authentication issue
- mstrick96
22 Jan 2016 20:51 #68939
by mstrick96
Preempt-rt wifi de-authentication issue was created by mstrick96
I've been testing the Preempt RT kernel on my Debian 8.2 system.
I seem to have a problem with the wifi deauthenticating. It seems to de-authenticate after a few hours of non-use.
The real time kernel generates an error message that it de-authenticated due to "error 15" which is a "four-way handshake error".
When I switch back to the kernel installed with Debian 8.2, there seems to be no problem.
Any Ideas how to fix this error in the real time kernel?
- Thank you received: 5330
22 Jan 2016 21:54 #68940
Replied by PCW on topic Preempt-rt wifi de-authentication issue
What Preemt-RT kernel version?
- mstrick96
22 Jan 2016 23:33 #68942
by mstrick96
Replied by mstrick96 on topic Preempt-rt wifi de-authentication issue
The PREEMPT-RT is
linux-image-3.2.0-4-rt-686-pae - Linux 3.2 for modern PCs, PREEMPT_RT
I'm running it on an old Dell Inspiron Pentium4 computer from about 2002.
23 Jan 2016 02:08 #68949
You might try a newer kernel (3.2 is pretty old)
- mstrick96
23 Jan 2016 17:05 #68981
by mstrick96
Thanks. What I did was to use the one from Wheezy. I'll looks for a newer version.
Lots to learn!
Lots to learn!
Time to create page: 0.099 seconds
