operating wire edm using linuxcnc
29 Jan 2016 18:14 #69248 by jimbo
operating wire edm using linuxcnc was created by jimbo
can I use linuxcnc to operate a charmise robifil 2020?
30 Jan 2016 06:56 #69262 by cmorley
Replied by cmorley on topic operating wire edm using linuxcnc
possible but probably not optimally without a lot of technical tinkering.
Linuxcnc has no (released) way to back up along the path, which I believe is fairly important to EDM.
There are probable work-arounds using offset components and there has been work on a development branch for path back-track ability.
AFAIK EDM is not a process often done with linuxcnc so there are not a lot of examples to lead you with.
In fact I can't locate an example on the wiki.
Chris M
31 Jan 2016 13:38 #69311 by cgc
Replied by cgc on topic operating wire edm using linuxcnc
Maybe this will help you :
Time to create page: 0.432 seconds
