Stepper config working but LinuxCNC doesn't operat
- caprio
30 Jan 2016 17:09 #69274
by caprio
Stepper config working but LinuxCNC doesn't operat was created by caprio
I got my electronics wired up and working. I'm using a Chinese parallel port board.
With Stepconf I can run the test and control all three axis's. When I start LinuxCNC
most of the machine section is grayed out. The manual jog controls don't operate the
steppers. I admit I'm a total newbe with LinuxCNC so I'm probably missing something
simple.
Did I miss a configuration step? I don't think I need to run Prnconf. That looks to be just for
Mesa boards.
Thank you.
simple.
Mesa boards.
Thank you.
- caprio
30 Jan 2016 17:24 #69275
by caprio
Replied by caprio on topic Stepper config working but LinuxCNC doesn't operat
Using F1 to reset E-stop and then F2 to turn power on worked.
Cursor keys now cause the axis's to move on the GUI but steppers
don't move.
don't move.
- caprio
30 Jan 2016 18:02 #69276
by caprio
I went through the Stepconf again and found that the 'Create Simulate Hardware Configuration' check box was checked.
Unchecked that box,saved config, relaunched LinuxCNC and it's not working.
- Thank you received: 2181
30 Jan 2016 19:08 #69283
Replied by cmorley on topic Stepper config working but LinuxCNC doesn't operat
is that it's NOW working or still NOT working.
If not working please post your config files.
Chris M
Chris M
- caprio
30 Jan 2016 19:20 #69286
by caprio
Sorry. I meant to say it IS working.
30 Jan 2016 19:54 #69288
I thought that might be what you meant
great!
Time to create page: 0.107 seconds
