RTAI-XML LinuxCNC compile, MTConnect integration?
31 Jan 2016 19:28 #69331 by comjon
I would like to know whether anyone has tried a LinuxCNC install on an Ubuntu compile based on RTAI-XML.
The goal is to create functionality similar to an MTConnect adapter on this box. This RTAI-XML 'target' would be accessed by another server running an MTConnect agent and webserver. The RTAI-XML documentation suggest this is possible, and part of the rationale behind the creation of RTAI-XML. If I am correct, RTAI-XML would serve as a bridging technology between the MTConnect agent on one box and LinuxCNC mill or lathe hardware operations on another.
Time to create page: 0.069 seconds
