It would be more common to have the Z axis home at 0.noted that the Max Limit on Z was only 0.1. I changed that to 8.0
changed the Axis 2 MIN_LIMIT to 0.0 and the MAX_LIMIT to -8.0.
The axes home properly but the Z axis gives "Can't jog joint 2 further past min. soft limit
norbertfarquharsh wrote: However, when I edited the gantry.ini file with gedit and changed the Axis 2 MIN_LIMIT to 0.0 and the MAX_LIMIT to -8.0
Yup, should have had my coffee first.The max limit must be > min limit.
