Z axis jog moves spindle only incrementally
  • norbertfarquharsh
  • Senior Member
  • Senior Member
04 Feb 2016 14:18 #69580 by norbertfarquharsh
Replied by norbertfarquharsh on topic Z axis jog moves spindle only incrementally
Thank again for the help and it now appears to be working and will run programs. I did use the configuration that RIck last sent me.
In answer to RIck's last question, I had read the section on Homing Sequence and will readily admit that I could never completely digest all the options and their interactions. Like it approximately says in the Sherlock Holmes stories, it seems simple once it is explained, but I could never fully explain it to myself and still am not confident that I could make anything work.
Thanks again to all.
Joe
04 Feb 2016 14:40 #69582 by Rick G
Replied by Rick G on topic Z axis jog moves spindle only incrementally
Glad you got it sorted out!
Homing has confused many others in the past, but seems simpler once you have it working.
Rick G
  • norbertfarquharsh
  • Senior Member
  • Senior Member
07 Feb 2016 20:02 #69744 by norbertfarquharsh
Thanks for all the help in the past. At this point, I have made progress with all the help.
But now need assistance in an area that I am not certain whether I should even ask for help as possibly there is a coding problem.
I am attaching two programs that I have written and will run on my machine, but in the first one (firstone.ngc_ the Z axis goes down towards the XY plane when the Z axis runs a positive number. However, when I run the second one (tabledrill.ngc) I would swear that the drill cycle is upward.
Excuse me if I am asking this question in the wrong forum.
Joe
  • norbertfarquharsh
  • Senior Member
  • Senior Member
07 Feb 2016 20:07 #69745 by norbertfarquharsh
It looks like t he attached files did not make it so I will try again.
File Name: firstone-2-3.ngc
File Size:0 KB
File Name: tabledrill-2.ngc
File Size:0 KB
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
07 Feb 2016 21:19 #69749 by Todd Zuercher
Replied by Todd Zuercher on topic Z axis jog moves spindle only incrementally
First I wonder if you've made a machine config blunder. Normally machines are configured such that Z- moves the spindle down towards the work piece and Z+ moves it up. So if you've configured your machine so that Z- moves up, a canned drilling cycle like G81 would drill up instead of down.
  • norbertfarquharsh
  • Senior Member
  • Senior Member
09 Feb 2016 00:36 #69802 by norbertfarquharsh
Thank you very much for your reply.
Originally, I had the Z axis configured to go positive down and then concluded that the canned cycles would not accept that so I changed it around so it was negative down and still could not get the canned cycles to work properly.
What you have confirmed is that I do not know how to properly program canned cycles.
So I will convert it back to negative down and try some more to get it to work.
Joe
09 Feb 2016 00:39 #69803 by andypugh
Replied by andypugh on topic Z axis jog moves spindle only incrementally
You may need to look at the G98 / G99 setting:
linuxcnc.org/docs/2.7/html/gcode/g-code.html#gcode:g98-g99
Time to create page: 0.206 seconds
