XFCE screen rotate only choice normal
  • jaro_p
  • jaro_p's Avatar Topic Author
  • Senior Member
  • Senior Member
09 Feb 2016 16:57 - 09 Feb 2016 18:16 #69861 by jaro_p
Replied by jaro_p on topic XFCE screen rotate only choice normal
It works, what can I do?
Last edit: 09 Feb 2016 18:16 by jaro_p.
  • jaro_p
  • Senior Member
  • Senior Member
09 Feb 2016 17:23 - 09 Feb 2016 18:15 #69863 by jaro_p
Last edit: 09 Feb 2016 18:15 by jaro_p.
09 Feb 2016 19:47 #69881 by Amedee
Replied by Amedee on topic XFCE screen rotate only choice normal
My first though would be to go to Jessie, and install linuxCNC there...
... But I saw this post this morning which tend to say it is not ready yet for Jessie :blush:
I am comfortable with Linux, but I am a LinuxCNC newbie. At this point in time, I am staying with Jessie as it works for me, but I can't recommend for others.
It would be nice if some LinuxCNC 'guru' could comment on this case ;)
  • jaro_p
  • Senior Member
  • Senior Member
10 Feb 2016 12:57 #69923 by jaro_p
Linux "guru" is probably not appear.
10 Feb 2016 15:49 #69930 by andypugh
Replied by andypugh on topic XFCE screen rotate only choice normal
Just an idea, but is there a good reason that the monitor can't be mounted the right way round?
If not, then you can _probably_ rotate the screen with an entry in xorg.conf. This seems to have more "authority" than xrandr, but is more complex to configure.
  • jaro_p
  • Senior Member
  • Senior Member
10 Feb 2016 16:29 #69935 by jaro_p
Sure, I have a lot of reasons - not least the one that has this option normaly just works.
Configuration with the xorg.conf I tried, but it always ended with a black screen.
10 Feb 2016 16:38 #69938 by andypugh
Have you asked the question anywhere else? We are reasonably OK at answering LinuxCNC questions here, but this seems like a general Debian(?) question, and you are more likely to find an answer on their forums.
  • jaro_p
  • Senior Member
  • Senior Member
10 Feb 2016 18:54 #69947 by jaro_p
Yes he questioned, but as you can read above in Debian it works.
Time to create page: 0.750 seconds
