Hi
My name is Vagelis and i am from Greece.
These days I am going to make some decisions about my cnc router electronic part
The machine that I am building will have
2.2 KW Water cooled spindle
1500mmX800mm working area
4 yaskawa servo motors (step-direction mode)
2 X SGMPH 400 Watt for x (the long) axis. That means Slaved axis, as two motors will move the gantry.
1X SMAH-400 Watt for y ( that moves z axis)
1XSGMAH-200 Watt for z
All these motors with yaskawa servo drivers
All motors have 2048 cpr with quadrature encoders and are rated at 3000 rpm. That means I will need 4*2048*3000/60=409600 pulses in order to keep using the accuracy that the motors offer. In other words I will need a motion controller that can produce at least 410mhz pulses. I have been told that the parallel port of a pc (even under linux or windows) can’t produce such high rate pulses in a reliable way. I have read that linux ( as a real time operating system) is far more better against windows but not as good to use parallel port in such high pulse rates( 400mhz+). Also I don’t want to use electronic gearing. The decision that I have to make is even go with
Solution A
Windows+ Mach3( or Mach 4) with motion controllers like
IP-CSmio-p
Ethenrnet smooth stepper ESS
OR
Solution B
CNClinux
With mesa motion controllers.
I have already made an internet search about solution A as the helpful people of
www.mycncuk.com
forum help me. The truth is that so far I didn’t find too much information about the linuxcnc solution for my machine. While looking the MESA electronics site I couldn’t understand what kind of controllers I will need.
Before I write down any question, I think that you must have in mind
1. I can install any version of linux in a pc but I am not an experienced user. That means I I am not familiar with console command line but if it will be necessary I will try and do the best I can
2. Last years I am a windows based system user
3. When I come against the electronics connection I will need support
Question 1
Is there any one who can tell me what mesa motion controller I will need for my machine?
Question 2
Is it easy with linux cnc and mesa motion controllers to have slaved motors ( for my x axis)?
Question 3
What will be the cost for the above solution
Question 4
Except the mesa motion controllers will I need some other equipments (BOB, Spindle speed controllers etc)
Question 5
Is there any other solution with linuxcnc, other than Mesa motion controllers
Thanks for your time
