How to hard-reset machine position in sim.axis?
10 years 8 months ago #70486 by justice
Newbie here, using the simulator in 2.7.4 to try to get a handle on mixing G92 with G54.
I've somehow managed to get my simulator to believe that the machine position is a couple hundred inches away from the origin. I can't home (error: end of move in home state 5). I can't G00 back to origin (error: Can't issue MDI command when not homed). Deleting the .VAR file didn't help.
How can I completely reset the simulator to factory defaults?
10 years 8 months ago #70507 by BigJohnT
10 years 8 months ago #70527 by justice
Thanks, but this doesn't actually work. As described above, I can't home the Z axis (maybe the sim is outside its limit switch, so it can't find the home switch?). One can't issue MDI commands without homing. So I really need a way to make the machine completely forget it's persistent state.
10 years 8 months ago - 10 years 8 months ago #70536 by BigJohnT
linuxcnc.org/docs/2.7/html/gui/axis.html#_menu_items
Take a look at Zero Coordinate System.
If you delete the .var file and the backup var file you have no more offsets. I suspect you did not delete the one your ini points to.
JT
Last edit: 10 years 8 months ago by BigJohnT.
10 years 8 months ago #70552 by justice
Thanks for your continued help, Big John. I tried about four different items in Machine->Zero Coordinate System; they each returned the "can't issue MDI command when not homed."
I am using a canned sim.axis machine called "axis.ini". It points to a VAR file called "sim.var". I shut down linuxcnc and deleted that file (and the .bak) from ~/linuxcnc/configs/sim.axis/. It did not exist anywhere else on the filesystem.
There's no effect, my Z-axis is still ridiculous, and won't home.
10 years 8 months ago #70555 by racedirector
Replied by racedirector on topic How to hard-reset machine position in sim.axis?
Try deleting position.txt in the config directory, that holds the axis positions between runs. Deleting it will set it all back to zero....
The following user(s) said Thank You: BigJohnT, justice
Time to create page: 0.497 seconds
