What Libraries Are In LinuxCNC?
- fc60
- Thank you received: 9
28 Feb 2016 17:08 #70753
by fc60
What Libraries Are In LinuxCNC? was created by fc60
This is directed toward the Administrators of the LinuxCNC application.
I would like to compile and run the apt360 software on the same machine running LinuxCNC.
reference link...
forum.linuxcnc.org/forum/31-cad-cam/30179-anyone-used-apt360
Are there sufficient libraries present to compile the software?
Also, can I run Axis on a stand alone computer for practice/experimenting?
Does the LinuxCNC *.iso provide for dual booting? i.e. Does it install GRUB?
With kind regards,
David
reference link...
With kind regards,
David
- Online
- Thank you received: 1476
28 Feb 2016 21:28 #70771
Replied by Todd Zuercher on topic What Libraries Are In LinuxCNC?
I have no experience with APT360, but the Linuxcnc install iso does support dual booting (yes Grub is installed), and Linuxcnc can be installed without any hardware to control to do simulations and experiment with. There is a "pure simulator" installation option that does not use any real time kernel as well that can be used for experimentation. Linuxcnc can even be installed into virtual machines for experimentation.
The following user(s) said Thank You: fc60
- fc60
28 Feb 2016 22:17 #70776
by fc60
Replied by fc60 on topic What Libraries Are In LinuxCNC?
What release of LinuxCNC are you referring to?
- Online
29 Feb 2016 03:16 #70791
To the best of my knowledge all of them. (but some of the older Ubuntu ones were easier to configure for it.)
Time to create page: 0.076 seconds
