Feed rates?
29 Feb 2016 22:40 #70836 by tjamscad
Feed rates? was created by tjamscad
I have a machine that should run 140 ipm on the liner and 160deg/min on the angular.
What does that make my AXES section look like. does trajectory planner over the axes section?
01 Mar 2016 00:01 #70839 by cmorley
Replied by cmorley on topic Feed rates?
Can you rephrase your question? I'm not sure what you are asking.
Are you asking for help to set the INI file properly or is the machine not doing what you think it should be doing.
Chris M
01 Mar 2016 07:52 #70848 by Rick G
Replied by Rick G on topic Feed rates?
In the TRAJ section the maximum velocity of a combined move is set in units per second.
linuxcnc.org/docs/2.6/html/config/ini_co...tml#sub:TRAJ-section
MAX_LINEAR_VELOCITY =
MAX_ANGULAR_VELOCITY =
So 140 ipm would be 2.333 ips.
MAX_VELOCITY = 5.0 - The maximum velocity for any axis or coordinated move, in machine units per second. The value shown equals 300 units per minute.
In the AXES section the maximum velocity of the axis is set in units per second.
MAX_VELOCITY =
Rick G
01 Mar 2016 13:30 #70859 by tjamscad
Replied by tjamscad on topic Feed rates?
I have a machine that has been running for a while but I am getting compaints about how slow it moves. What I want to accomplish is to get it running the speeds the machine was orginally designed for then if I get complaints I can say it is running to factory specs.
01 Mar 2016 13:54 #70861 by andypugh
Replied by andypugh on topic Feed rates?
Is the machine running a non-trivial kinematics? If so then there are a couple of extra limits that come in to play.
01 Mar 2016 15:07 - 01 Mar 2016 15:08 #70862 by Todd Zuercher
Replied by Todd Zuercher on topic Feed rates?
Also, what version of Linuxcnc is it running? What does a sample of the code that is running too slow look like?
There are issues with the new trajectory planner and running code that uses axis other than XYZ. When the new planner runs into g-code that has movement in A, B, C, W, U, or V axis, naive-cam-detection is turned off, and the old 1 line look a head speed limit is reinstated.
Last edit: 01 Mar 2016 15:08 by Todd Zuercher.
01 Mar 2016 21:21 #70870 by tjamscad
LinuxCNC Ver. 2.4.0~pre
# Trajectory planner section
[TRAJ]
AXES = 9
COORDINATES = X Y Z A B C U V W
HOME = 0 0 0 0 0 0 0 0 0
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 1.67
MAX_VELOCITY = 4.0
MAX_ACCELERATION = 100.0
DEFAULT_ACCELERATION = 1.0
TLO_IS_ALONG_W = 1
# Axes sections
[AXIS_0]
TYPE = LINEAR
HOME = 0.000
MAX_VELOCITY = 1.6
MAX_ACCELERATION = 5.0
INPUT_SCALE = 20000
OUTPUT_SCALE = 1.000
MIN_LIMIT = -121.850
MAX_LIMIT = .70
COMP_FILE_TYPE = 1
COMP_FILE = Xaxis.cmp
FERROR = 10.0
MIN_FERROR = 10.0
HOME_OFFSET = 0.5
HOME_SEARCH_VEL = 0.3
HOME_LATCH_VEL = -0.01
HOME_USE_INDEX = yes
HOME_IGNORE_LIMITS = yes
HOME_SEQUENCE = 1
DEADBAND = 8e-05
PID_MAX_VEL = 0
P = 250
I = 0
D = 4
BIAS = 0
FF0 = 0
FF1 = 2.06
FF2 = 0.04
02 Mar 2016 13:14 #70903 by andypugh
Which kinematics is it running?
Is it really a 9 axis machine? What is it?
02 Mar 2016 13:28 #70905 by Todd Zuercher
For starters you say you want 140 inches/min on your linear axis, but you have your X axis set to a max vel of 96 (1.6ips).
You didn't share what your settings are for any other axis, or what your G-code looks like.
02 Mar 2016 14:17 - 02 Mar 2016 14:29 #70907 by tjamscad
It is a 5 axis machine X,Y,Z,A,B.
I have no idea what kinematics it is running.
All liner axes should be 140ipm and all angular should be 160 deg/min.This is the problem the shop is complaining about it being to slow. Also what would "rapid" be called in LinuxCNC?
After homing the machine the operator types in MDI G0G90X0Y0Z0A0B0.
Last edit: 02 Mar 2016 14:29 by tjamscad.
Time to create page: 0.433 seconds
