masa card
- ronwhite
01 Mar 2016 13:04 #70855
by ronwhite
masa card was created by ronwhite
Does anyone know a replacement for the masa card, tried contacting masa no response.
- Thank you received: 4648
01 Mar 2016 13:19 #70856
Replied by andypugh on topic masa card
Mesa card?
Which one? Which continent are you on?
The following user(s) said Thank You: ronwhite
- BigJohnT
- Thank you received: 994
01 Mar 2016 13:26 #70857
by BigJohnT
Replied by BigJohnT on topic masa card
I can supply the more common Mesa cards at mesaus.com
JT
JT
- phillc54
- Thank you received: 2100
01 Mar 2016 20:55 #70869
by phillc54
Replied by phillc54 on topic masa card
I had the same problem as you then I found out about mesaus.com which is operated by JT from these forums and was then able to get what I wanted. Highly recommended...
Cheers, Phill
Cheers, Phill
Time to create page: 0.123 seconds
