acces to folders
- Ncmill.ts
01 Mar 2016 17:59 - 01 Mar 2016 20:50 #70867
by Ncmill.ts
acces to folders was created by Ncmill.ts
hi i have recently change to debian wheezy only to days ago .im just trying to copy some folders to lib/firmware/hm2/ and i cant
because i dont have acces to do so.
i probably need root acces how do i get that so can copy and paste these folders ???.
im trying to copy xml and .pin files for mesa 5125-7177card to correct folder in order to get pncconfig working properly.
Last edit: 01 Mar 2016 20:50 by Ncmill.ts. Reason: additional info
- Thank you received: 2173
02 Mar 2016 02:31 #70885
Replied by cmorley on topic acces to folders
to you know your password?
in a terminal type:
sudo thunar
it will ask for your password then fire up a file manager with sudo root access.
just be careful with it :0
Chris M
in a terminal type:
sudo thunar
Chris M
- Ncmill.ts
02 Mar 2016 14:19 #70908
by Ncmill.ts
Replied by Ncmill.ts on topic acces to folders
sudo thunar works well,thank you
i have flashed my 5125card and done a reload everything seem to be in order but when im in pncconfig and choosing" board name and firmware i cant choose num of pwm generators.
my choices of board are:5i25-internal data or 5i25.
firmware:7i77x2 with one 7i77 or :7i77x2.
i flashed my 5125card with 5i25_7i77x2.bit
when choosing num of pwm generator the number allways returns to: 0
any ideas??.
any ideas??.
- gaston48
- Thank you received: 5
08 Mar 2016 22:00 #71249
by gaston48
Replied by gaston48 on topic acces to folders
Hello,
j have the same problem !
- Thank you received: 4648
09 Mar 2016 12:36 #71265
Replied by andypugh on topic acces to folders
If you look at page 5 of www.mesanet.com/pdf/parallel/7i77man.pdf you will see that the 7i77 does not use PWM.
The analogue outputs are digitally controlled by the smart-serial interface.
So, you will find the analogue outputs on the smart-serial tab (probably, I can't check right now) rather than the 5i25 config.
- gaston48
09 Mar 2016 13:35 #71270
by gaston48
hello Andy
yes, but my pncconf is blocked ?
#71269
#71269
Time to create page: 0.295 seconds
