hal and halui and pyvcp
- albova
03 Mar 2016 09:13 #70954
by albova
hal and halui and pyvcp was created by albova
hi
I have a pyvcp panel should to show the spindle speed .
I seem to have configured everything correctly, but obviously it is not.
INI files
[ HAL ]
HALUI = halui
HALFILE = prova.hal
HALFILE = simulated_home.hal
HALFILE = custom.hal
HALFILE = jog.hal
POSTGUI_HALFILE = custom_postgui.hal
HAL file
net spindle-cmd-rpm => pwmgen.0.value
net spindle- cmd - rpm < = motion.spindle -speed- out
CUSTOM POST GUI .HAL file
net speed_out pyvcp.spindle_rpm < = spindle- cmd - rpm
Custum PANEL.XML file
< Halpin > " spindle_rpm " < / Halpin >
when I start LinuxCNC I get the following error :
pin spindle- cmd - rpm does not exist
where am I wrong ?
regads Alessandro
INI files
[ HAL ]
HALUI = halui
HALFILE = prova.hal
HALFILE = jog.hal
HAL file
where am I wrong ?
regads Alessandro
03 Mar 2016 13:37 #70964
Replied by andypugh on topic hal and halui and pyvcp
I assume that the spaces in your pin names are not there in the actual code?
spindle-cmd-rpm is a _signal_ and must always be first in the net command.
You can't net a signal to a signal.
If you change the second line in the postgui HAL tothen it should work.
net spindle-cmd-rpm < = motion.spindle-speed- out .... net speed_out pyvcp.spindle_rpm < = spindle- cmd-rpm
net spindle-cmd-rpm pyvcp.spindle_rpmPlease Log in or Create an account to join the conversation.
- albova
03 Mar 2016 13:44 #70966
by albova
Replied by albova on topic hal and halui and pyvcp
hi Andypugh,
it' s ok now
solved
many thank's
Alessandro
it' s ok now
solved
many thank's
Alessandro
Time to create page: 0.175 seconds
