Proper use of paramsaver
- albova
04 Mar 2016 14:20 #71031
by albova
Proper use of paramsaver was created by albova
hi
I have a spinbox pyvcp and I would like to save and load the value every time I turn off and turn on LinuxCNC. I saw that I could do with paramsaver but I can not figure out how to use it.
some more information?
Alessandro
Alessandro
- Thank you received: 4648
04 Mar 2016 15:51 #71041
Replied by andypugh on topic Proper use of paramsaver
There is a sample configuration here: www.mgware.co.uk/LinuxCNC/param-saver.html
But I imagine that is where you got it from?
- albova
04 Mar 2016 15:55 #71042
by albova
Replied by albova on topic Proper use of paramsaver
yes
exactly where I need to put
"loadusr -W paramsaver f=NNN s=NNN b=NNN filename=xxxxxxx onstart=0/1 onexit=0/1 " ?
04 Mar 2016 16:14 #71045
In the HAL file. Like the example in the HAL file on that page.
- albova
04 Mar 2016 18:43 #71058
by albova
hi
another question:
i need to write a variable eg. #35 into pyvcp spinbox halpin vistoll
i tried with file ini mdi_command so when i push a button execute :
MDI_COMMAND = #<_hal[pyvcp.vistoll]> = #35
but it's wrong seem i read halpin but i does not write.
when i read with another button it's ok
MDI_COMMAND = #35=#<_hal[pyvcp.vistoll]>
Is there a solution ?
Alessandro
another question:
Alessandro
04 Mar 2016 21:19 #71062
G-code access to HAL is read-only.
If you need to pass a value from G-code to HAL use the motion.analog-out pins and M68.
linuxcnc.org/docs/2.7/html/gcode/m-code.html#mcode:m68
Time to create page: 0.182 seconds
