Need help with C41 PWM HAL
10 years 7 months ago #71071 by rreddy2go
Hello, I've trying to gain spindle control using a CNC4PC C41 PWM to control my X2 spindle. I've gone through the basic HAL tutorial as well as the spindle control examples on the website. I thought that I had a grasp of what was needed, but the attached HAL resulted in a kernel panic. If anyone could give me some advice on what I'm doing wrong, I would greatly appreciate it. A working HAL example would be even better.
10 years 7 months ago #71074 by PCW
Replied by PCW on topic Need help with C41 PWM HAL
A panic is probably unrelated to your hal file and more likely related to a general problem
The following user(s) said Thank You: rreddy2go
10 years 7 months ago #71078 by rreddy2go
Andy,
I've been unable to reproduce the kernel panic. But when I try to start linuxcnc, the debug information says that a configuration error is preventing linuxcnc from starting.
10 years 7 months ago #71082 by Rick G
Replied by Rick G on topic Need help with C41 PWM HAL
Best if you post the error information.
Rick G
10 years 7 months ago #71084 by rreddy2go
Here is the message that was generated this morning.
10 years 7 months ago #71089 by cncbasher
please post in full , your config folder as an archive and attach to this thread .,
you have a miss configuration somewhere , without seeing your configs , there is nothing we can do
Time to create page: 0.409 seconds
