jogging z axis while machine is cutting
16 Mar 2016 22:54 #71748 by jairoesp
jogging z axis while machine is cutting was created by jairoesp
Hi everybody, I would like to jogging z while the machine is cutting, I did it with mach3 but I would like to do it with EMC2. How can I do that?
Thanks for your help.
17 Mar 2016 13:18 #71788 by andypugh
Replied by andypugh on topic jogging z axis while machine is cutting
You can't, really. Jogging is disabled in Auto mode (ie when running G-code).
Can you explain why you want to do this? There is probably a solution other than jogging.
17 Mar 2016 13:40 #71792 by emcPT
Replied by emcPT on topic jogging z axis while machine is cutting
Most likely for manual touch height control?
Try to really implement it though one of the solutions available (for real automatic THC control) and you will see that is worth it. Quality of the cut will be better and you can run away from the machine smoke while it is cutting!
17 Mar 2016 16:33 #71811 by jairoesp
Replied by jairoesp on topic jogging z axis while machine is cutting
Sometimes the material surface is not always very regular and the router can not engrave properly.
With a plasma cutter I had this problem when the THC was damage, I wanted to do it manually because I needed finish the work and do not have to wait until the THC were replaced.
17 Mar 2016 16:43 #71816 by andypugh
Sometimes the material surface is not always very regular and the router can not engrave properly. .
In that case, look at this thread:
forum.linuxcnc.org/forum/38-general-linu...ealtime?limitstart=0
Time to create page: 0.131 seconds
