jog when large files are loaded
- jbraun
- Thank you received: 15
27 Mar 2016 15:42 #72215
by jbraun
jog when large files are loaded was created by jbraun
When running a 84000+line file Axis did not update smoothly, this was expected.
What I didn't anticipate was simply loading that file made keyboard jogging very unpredictable.
What part of best practice was I ignoring ?
- Thank you received: 2175
27 Mar 2016 19:25 #72222
Replied by cmorley on topic jog when large files are loaded
Keyboard jogging is not under realtime control so will be unpredictable while AXIS is busy.
Using a MPG would be much better. or don't jog while loading a program.
Chris M
Chris M
The following user(s) said Thank You: jbraun
- jbraun
28 Mar 2016 04:43 #72232
by jbraun
Replied by jbraun on topic jog when large files are loaded
The program was loaded, or at least the progress bar gave that indication.
Good thing this machine doesn't have enough power to hurt itself as jog pushed it right past the soft limits.
An mpg would be nice but hardware limit switches are looking like a must-have.
From now I'll do touch-offs before calling a file.
28 Mar 2016 05:04 #72233
had you homed it? it shouldn't move past soft limits - something seems wrong there.
Chris M
Chris M
- Rick G
- Thank you received: 114
28 Mar 2016 07:03 #72236
by Rick G
Rick G
Replied by Rick G on topic jog when large files are loaded
That is probably a better practice and avoids Axis having to update after the touch off.From now I'll do touch-offs before calling a file.
Rick G
- jbraun
29 Mar 2016 01:43 #72285
by jbraun
You're right, it wasn't re-homed after I shut down in panic/confusion. Confirmed by recreating the situation. The gcode ran perfectly so all ended well.had you homed it? it shouldn't move past soft limits
Time to create page: 0.298 seconds
