Lathe/turning with fusion 360
- midyo
28 Mar 2016 12:59 #72245
by midyo
Lathe/turning with fusion 360 was created by midyo
Is there anybody using fusion here to produce turning g code?
- mariusl
29 Mar 2016 08:10 #72298
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Lathe/turning with fusion 360
I am using Fusion 360 for mill and lathe.
Regards
Marius
www.bluearccnc.com
- midyo
29 Mar 2016 08:14 #72300
by midyo
Replied by midyo on topic Lathe/turning with fusion 360
Hi Mariusl, could you let me have a copy of your lathe PP please?
- mariusl
29 Mar 2016 08:32 #72301
by mariusl
Regards
Marius
www.bluearccnc.com
I have not used lathe for a while but I just used the latest generic Linuxcnc (EMC2) PP. I am cutting parts daily on the mill using the same generic PP.
Regards
Marius
www.bluearccnc.com
- mariusl
29 Mar 2016 09:13 - 29 Mar 2016 09:29 #72304
by mariusl
Regards
Marius
www.bluearccnc.com
I just tested the lathe PP and it is broken. Says the PP is unsigned. Whatever that might mean.
Looks like everyone is using the Tormach PP. It has to be modified somehow with regard to the tool change code. I have the Tormach PP but have not used it yet.
@Andy, do you have a modified version?
Regards
Marius
www.bluearccnc.com
Last edit: 29 Mar 2016 09:29 by mariusl.
- midyo
30 Mar 2016 23:41 #72423
by midyo
Weird, at 8:10 you were using lathe and by 8:32 you had'nt used lathe for a while - is this just to increase post numbers?
- mariusl
31 Mar 2016 06:48 #72440
by mariusl
Regards
Marius
www.bluearccnc.com
I dont think your comment warrants a response but here goes anyway.
I use my lathe all the time but with NGCGUI. I only use CAM for lathe when I have to turn a profile. That I have not done in a while.
Does that satisfy you better?
I use the Tormach post. Now you can go edit your own post for being nasty.
Regards
Marius
www.bluearccnc.com
Time to create page: 0.105 seconds
