weird behavior
31 Mar 2016 01:53 - 31 Mar 2016 02:33 #72432 by clayton cramer
weird behavior was created by clayton cramer
I have been using the Debian Wheezy version for some time without problems and suddenly I get this weird behavior.
g01 g40 g49 f100.00
(93493 5.930 long)
g90 x0.5 y1.000 f100
g90 z0.02 f100
g90 z-0.02 f0.1
g90 z0.02 f100
g90 x1.500 y1.0 f100
g90 z0.02 f100
g90 z-0.02 f0.1
g90 z0.02 f100
g90 x4.530 y1.0 f100
g90 z0.02 f100
g90 z-0.02 f0.1
g90 z0.02 f100
g90 x0 y0 z2 f100
When I step through it, g90 z0.02 f100 only moves z to 0.00. The subsequent command actually moves to z0.02.The g90 x4.530 y1.0 f100 actually takes me to x4.530 y0.75. Is there something magical I should be looking for? Entering commands through MDI gives similar results. It really helps when the mill vise is aligned correctly with the table! Solves the Y axis, problem but not z0.02 not taking effect until next command.
Last edit: 31 Mar 2016 02:33 by clayton cramer.
31 Mar 2016 05:30 #72438 by Rick G
Replied by Rick G on topic weird behavior
Have you tried reducing the speed? Perhaps f50 instead of f100 on the problem moves?
Is G61, G64 set?
linuxcnc.org/docs/html/gcode/g-code.html#gcode:g64
Rick G
31 Mar 2016 11:47 #72455 by andypugh
Replied by andypugh on topic weird behavior
What do you mean by this? Do you mean that G1 Z0.02 completes with the DRO reading 0.00?
Is the DRO reporting commanded or actual position?
Servo or stepper?
31 Mar 2016 14:38 #72473 by clayton cramer
Replied by clayton cramer on topic weird behavior
The DRO is reporting actualposition. Should I try commanded position instead?
31 Mar 2016 14:39 #72474 by clayton cramer
I will try those. Thanks.
31 Mar 2016 14:42 #72475 by andypugh
I think it is worth a try.
Is the system servo or stepper?
31 Mar 2016 19:43 #72490 by clayton cramer
Not sure. Sherline 5400 CNC.
