Raspberry Pi 3
- markehle@gmail.com
31 Mar 2016 13:47 #72467
by markehle@gmail.com
Raspberry Pi 3 was created by markehle@gmail.com
Folks - now that the Raspberry 3 is out, does that change anything with respect to installing Linuxcnc? Seems to me that the new unit finally has enough power to run LinuxCNC well.
- Thank you received: 4652
31 Mar 2016 14:16 #72471
Replied by andypugh on topic Raspberry Pi 3
Do you have any idea what the latency would be like?
Were you thinking of using the GPIO pins or something else? SPI might be an option. Etthernet isn't, with the Pi, as it is on the USB bus.
www.frank-durr.de/?p=203
Time to create page: 0.197 seconds
